STEERING WHEEL REMOVAL AC5040
scratch67 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote scratch67 Quote  Post ReplyReply Direct Link To This Post Topic: STEERING WHEEL REMOVAL AC5040
    Posted: 24 Aug 2020 at 3:34pm
Having a tuff time getting wheel off. Been using a bearing puller. Soaking top bowl/shaft with penetrating oil now.
But I wonder if it is threaded on.
Anyone know if it’s threaded or pressure fit? My guess is pressure.
Will be applying heat on it tomorrow.
Any other tricks I should try?
Thanks
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 24 Aug 2020 at 9:15pm
It's probably splined.  I have never been able to remove one without destroying it, so make sure you can get a new one first.  I know getting parts for those 5000 series tractors can be a little tough.
If so, lots of heat and penetrating oil will probably be needed to get your old one removed.
Gary Burnett View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Burnett Quote  Post ReplyReply Direct Link To This Post Posted: 25 Aug 2020 at 5:24am
Loosen the nut some,then take a dull pointed air chisel put it in the center of the steering shaft.Then pull up on the hub of the of the steering wheel,then let the chisel hammer, usually
will pop loose immediately.Changed one out on a 1365 Oliver a while back same steering shaft.
