Snap Coupler Blade to fit CA
ddlong View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ddlong Quote  Post ReplyReply Direct Link To This Post Topic: Snap Coupler Blade to fit CA
    Posted: 19 Aug 2020 at 10:29pm
I have a Snap Coupler Oxnard blade that fit my WD45 and the D19 my son & I purchased last year. Was planning on mounting the blade to a CA but found out the CA hitch arms are narrower than the other Snap Coupler hitch tractors?
So the question is: is there a Oxnard blade made to fit the CA?
I’m in the process of purchasing a CA to mount that blade on, but if it will not fit, I’m stuck finding another blade specific to the CA.
Don
Post Options Post Options   Thanks (0) Thanks(0)   Quote ddlong Quote  Post ReplyReply Direct Link To This Post Posted: 19 Aug 2020 at 10:31pm
This is the blade I have.
Edited by ddlong - 19 Aug 2020 at 10:41pm
AllisD17AndyOk View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AllisD17AndyOk Quote  Post ReplyReply Direct Link To This Post Posted: 19 Aug 2020 at 11:03pm
Can you drill new bolt holes and move the lift links in to match the ca?
Eldon (WA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eldon (WA) Quote  Post ReplyReply Direct Link To This Post Posted: 19 Aug 2020 at 11:44pm
Yes I have sc blades with 2 sets of holes on the top strap. Subtract the distance between both and divide by two and drill another set of holes.
ALLIS EXPRESS!
This year:
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 20 Aug 2020 at 5:27am
When  'sleepy' Mr. Sun decides to get up, I'll go measure my blade 4 hole bar. I KNOW it fit on my '51 CA and it still firs on my D-14s.
I need to go remove more 'stuff' from next door so 'two birds thing...' sigh
Jay
Trinity45 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Trinity45 Quote  Post ReplyReply Direct Link To This Post Posted: 20 Aug 2020 at 7:18am
I had a snap coupler blade for my CA but sold it years ago, now I wish I had it back.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 20 Aug 2020 at 7:19am
well I still have the blade, but not the CA......sniff,sniff.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ddlong Quote  Post ReplyReply Direct Link To This Post Posted: 20 Aug 2020 at 8:33am
Anyone able to post a picture of the extra holes or a blade attached to a CA?
Thank you for the help!!
Don
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eldon (WA) Quote  Post ReplyReply Direct Link To This Post Posted: 21 Aug 2020 at 10:09pm
Email me at Ejons@comcast.net and I will send you a pic
ALLIS EXPRESS!
This year:
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 22 Aug 2020 at 6:36am
the dimensions.....
the bar is 1.5" x 31.5" x 3/8" thick with rounded ends
inner holes are spaced about 27.5"
outer holes are spaced about 30"
center hole is ,well, at the center..
all 5 holes are 3/4" diameter
I'd make one out of 3/8" plywood first, before making a steel one.
wood's a lot easier to drill and cut !
Jay
This page was generated in 0.069 seconds.
