CA steering problem |
Post Reply ![]() |
MikeinMadisonCo. ![]() Silver Level ![]() ![]() Joined: 11 Sep 2009 Location: Southern Iowa Points: 63 |
![]() ![]() ![]() ![]() ![]() Posted: 29 Aug 2010 at 11:14am |
The wife's CA (wide front) has been sitting outside all summer with very little use. I tried to move it the other day and it would not turn...like having power steering without any fluid only this does not have power steering. We have had a ton of rain this year do you suppose water got in somewhere? Thanks folks!
If the horse dies....get off!
Wil M (NEIA) ![]() Orange Level ![]() ![]() Joined: 11 Sep 2009 Location: NEIA Points: 478 |
Sounds like something rusted together. I had to change the front part of mine where the steering arm goes in and the pedistal is bolted to. It was very hard to steer and the bushings in the shaft were setting up. Wil |
"Yet there are soulless men whose hand and brain tear down what time will never give again." Anderson M Scruggs
pumpkin man ![]() Silver Level ![]() ![]() Joined: 10 Apr 2010 Location: Michigan Points: 106 |
grease the spindles with the front wheels off the ground turning back&forfth while you grease check the steering box 4 water if full take the adj. screw out thats the one be hind the starter to drain flush with fuel oil refill with gear lube dont forget to check trans- rear end & Hdl. if water in trans drain them all refill motor I use 15/40 year round.
wkpoor ![]() Orange Level ![]() Joined: 25 Apr 2010 Location: Amanda, OH Points: 825 |
Might be handy to jack it at the torque tube to unload front end and maybe tell then where its locked up.
Post Reply ![]() |
