Combi Units ??
FREEDGUY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote FREEDGUY Quote  Post ReplyReply Direct Link To This Post Topic: Combi Units ??
    Posted: 15 Aug 2020 at 5:22pm
Dad is in the "market" for at the very least, a "pole" saw. I borrowed a friend of mine's Stihl pole saw 3 year ago and dad was impressed to say he least Ouch. He priced it out at the local dealer  recently and almost had "another" bypass surgery Confused. This was/is a gas powered unit with 3 extension poles to get up to 12-14' standing on the ground. Are there comparable units without the "Stihl" $$ ?? Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hubert (Ga)engine7 Quote  Post ReplyReply Direct Link To This Post Posted: 15 Aug 2020 at 6:24pm
I have one of the Stihl Combi units and I love it. Pole saw w/extension, garden tiller and weed eater. Yes they are expensive but I don't think you will find anything comparable at a lesser price. I use mine a lot clearing limbs around the edge of fields so I don't have to fight the limbs when I bush hog. The manual says to use only one extension but if you can handle the extra length go for it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote FREEDGUY Quote  Post ReplyReply Direct Link To This Post Posted: 15 Aug 2020 at 6:36pm
Thanks Hugh. Apparently there are different P/H cc's that dictate the # of extensions ??
No question about it, the "borrowed" machine was a BEAST WinkWink !!
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 15 Aug 2020 at 7:39pm
mine is about 8 ft long and extends out ONE to maybe 15 ft.... you PAY for quality.
Post Options Post Options   Thanks (0) Thanks(0)   Quote FREEDGUY Quote  Post ReplyReply Direct Link To This Post Posted: 15 Aug 2020 at 7:50pm
Does ECHO make a similar combi system ??
DSpears N IL View Drop Down
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSpears N IL Quote  Post ReplyReply Direct Link To This Post Posted: 15 Aug 2020 at 9:37pm
I also have the 90CC combi unit that I used with the hedge trimmer to keep my willows clear to mow the lawn so not to fall off the mower. I then added pole saw, leaf blower, string trimmer, and this year purchased the sidewalk edger!  My neighbor has used mine several times the last several years! My son has borrowed it for a long month last year (boy,I sure missed it) and he bought the larger 130CC motor for himself!
Only sthiel for me!
You pay for it Once!
But, it runs for ever with good maintenance!
DeWayne
Dakota Dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dakota Dave Quote  Post ReplyReply Direct Link To This Post Posted: 15 Aug 2020 at 11:01pm
I have a remington polesaw combo unit. Works greatbut gets eavy with two extensions. Uses the same attachements as my weedwackers.
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless dude Quote  Post ReplyReply Direct Link To This Post Posted: 16 Aug 2020 at 1:30am
mine is just a B&D battery one. it has worked very well for 2 years now. has 2 extensions that can be or don't need to be used, easy to change it. cuts alot with one battery. it's the 20V one. i didn't think i needed a gas one...and so far i don't. HF has a battery one too... but i've never seen it, the price was comparable with B&D. i'm thinking that any of these..gas/electric, when you need a new chain/bar...it'll hafta be made up or ordered from ? as i've never seen replacements for any brand of them.
IBWD MIke View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 16 Aug 2020 at 5:53am
I have a 'Combi unit' with pole saw and one extension, love it! The thought of an additional extension, wow, you'd have to be some kind of monster to run it that way. If I want to work higher, I get someone to run the 6080 with me in the loader bucket.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dakota Dave Quote  Post ReplyReply Direct Link To This Post Posted: 16 Aug 2020 at 11:05am
WalmRt had replacement chains Oregon chains made for my modle polesaw was marked down to $5
Ray54 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ray54 Quote  Post ReplyReply Direct Link To This Post Posted: 16 Aug 2020 at 11:11am
The first of that type saw was put together by a fruit farmer in Idaho and he used Echo weed eater motors,back about 1980. The first units he sold had no oiler on the chain. Then Echo bought his rights and added a oiler.
The Echo units are the only ones I have seen out in use. But there is nothing comb about them. The motor and about 6 foot of pole that you can slide out about another 5 foot or so. Making a 10 to 12 foot long unit.
Back in the beginning they where 700 to 800 bucks.
If you want cheap there are a lot of electric saws on a pole. Always find other use's for a generator. But I guess you add a saw and generator up price wise not much cheaper. But it is a combo deal.LOL
john(MI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote john(MI) Quote  Post ReplyReply Direct Link To This Post Posted: 16 Aug 2020 at 11:39am
Ryobi has a unit, battery.  All my other battery tools are ryobi so if I BUY ONE IT'LL BE Ryobi.  I think Harbor Freight has a combo unit.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 16 Aug 2020 at 1:05pm
Used $600+ son in laws Sthil...extends to 15ft?...its a load out there but it is a wicked tool
DonBC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DonBC Quote  Post ReplyReply Direct Link To This Post Posted: 16 Aug 2020 at 7:28pm
I have a 120v electric Remmington pole saw that was inexpensive and has worked well for me. I am only using it around the yard and not for serious work. If I am not near power I put my generator in my garden trailer and take power with me.
Scott B View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Scott B Quote  Post ReplyReply Direct Link To This Post Posted: 18 Aug 2020 at 2:25pm
I’ve had mine 10 or 12 years. Brush cutter, pole saw and weed eater. Love the versatility. And w the quality of Stihl, it’s earned its money. I did have to think about the price a bit, but glad I did it.
That Saw is awesome to use taking out low hanging limbs that are problems when brush hogging.
D17 Series 1
Allis B- 1939
Allis B- 1945
