Allis Chalmers D17 |
Post Reply ![]() |
jeffgarc12 ![]() Bronze Level ![]() ![]() Joined: 01 May 2020 Location: Kansas Points: 43 |
![]() ![]() ![]() ![]() ![]() Posted: 10 Aug 2020 at 3:23pm |
I have an Allis Chalmers D17 that I had parked outside for the night and it started right up when I moved it out of our shop but the next morning, nothing. I was also wondering if the D17's were positive grounds
Boss Man ![]() Orange Level ![]() Joined: 03 Mar 2018 Location: Greenleaf, WI Points: 617 |
If it hasn't been converted to an alternator it should be positive ground.
SteveM C/IL ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Location: Shelbyville IL Points: 8636 |
Positive from factory....check which battery post is grounded. Could be like my cousin's where he replaced battery and hooked up neg ground. Still started and ran....ignorance is bliss.
But what could cause not to start, it is not doing anything at all after I turn on the fuel and turn the key no clicks no nothing.
CrestonM ![]() Orange Level ![]() ![]() Joined: 08 Sep 2014 Location: Oklahoma Points: 8455 |
I would check to see if you have power at the battery, distributor, and starter. A test light is useful for that.
Could it be shorting out along those spots
Clean and tighten all connections. Sounds like you lost conductivity or else the battery died. Don't know if regulator could stick points and run system down when off? Doubt you are shorting anything. You would be cooking wiring somewhere.
Edited by SteveM C/IL - 11 Aug 2020 at 9:17pm |
frnkeore ![]() Silver Level ![]() Joined: 07 May 2019 Location: Southern Oregon Points: 362 |
In this case, the first thing I would do, is pull the battery or pull the cables off it and charge the battery. Then take the charger off and test the voltage. That will tell you if the battery is good. The battery has to hold a charge, before you can check anything. A quick check for battery drain, if the battery is good, is to take one cable off and then touch it the battery terminal. If everything is off (including ign switch), and there is any spark, there is a drain somewhere. But, first check the battery, they can die, overnight. It has happened to me. |
Frank
1959 D17 Series I #24001+, '59 D14 '55 & '59 Ford 850 & 861 Ferguson TO 35 Deluxe, Oliver 70 and 5 more. |
Post Reply ![]() |
