Wheel adjuster broke. A/C D-17
ttiiggy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ttiiggy Quote  Post ReplyReply Direct Link To This Post Topic: Wheel adjuster broke. A/C D-17
    Posted: 28 Aug 2010 at 5:02pm
I need to find something to make this tractor functional again.
I don't use the power adjustable width option.  It could be solid for all I need.
There are four of these bolted onto each hub and they interface with the curved sliders on the rim.
Anywhere I can get new or used ones of these or suggestions for what to do instead?
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 28 Aug 2010 at 5:18pm
Parts should be available, check with the vendors on this site. You could also find a used combine that has wheels that will bolt right on without the power adjust rims.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Skyhighballoon(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 28 Aug 2010 at 5:18pm
Should be the same as WD/WD45 with spin outs...not too hard to find used.  Some individuals on here may have them.  Tony's tractors's list them on their web site reburbished.
http://www.tonystractors.com/acr.htm
I bet Jim at OKTractor has them as well if you call him.
http://www.oktractor.com
Mike
1968 Gleaner EIII w 10' & 330
1969 180 gas
1965 D17 S-IV gas
1963 D17 S-III gas
1956 WD45 gas NF PS
1956 All-Crop 66 Big Bin
norm [ind] View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote norm [ind] Quote  Post ReplyReply Direct Link To This Post Posted: 28 Aug 2010 at 8:22pm
 we have buckets of them   frozen an freed up  1-800-254-3116  visa -discover- master cards
Clay View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Clay Quote  Post ReplyReply Direct Link To This Post Posted: 29 Aug 2010 at 1:35am
I adjusted the wheels on my neighbors D-17 yesterday.
Only one adjuster was a real booger. The others were not too bad.
I was mowing with it today and could hear the right wheel hit the stops on occasion.
All the cams are in the full lock position.
Any ideas?
Don(MO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 29 Aug 2010 at 8:58am
Clay, Are your rails on the wheel worn down, or the wedge locks worn down?
Don
Eldon (WA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eldon (WA) Quote  Post ReplyReply Direct Link To This Post Posted: 29 Aug 2010 at 9:25am
Clay I would move them to the next hole....sounds like the rails are worn in that spot.
ALLIS EXPRESS!
This year:
Post Options Post Options   Thanks (0) Thanks(0)   Quote ttiiggy Quote  Post ReplyReply Direct Link To This Post Posted: 03 Oct 2010 at 3:54pm
Clay, are the spacer pieces still in there on yours?
I finally got mine put back together.
Was some difficult because the bolts are seized up in the stops so I couldn't just slide this adjuster down the rail.
My rails are worn a bunch where these were and have been banging around for a long time.
Clay View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Clay Quote  Post ReplyReply Direct Link To This Post Posted: 03 Oct 2010 at 9:18pm
I will have to take them apart and check.  I believe the spacer pieces are still in place.
Not sure when I will get time to check them.  Been busy doing lots of things.
Just got back from the truck show at 4 States in Joplin.  Had to help with a Peterbilt owned by Farmers Oil.  The truck (Road Hammer) got first in paint.
acdeerboy123 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote acdeerboy123 Quote  Post ReplyReply Direct Link To This Post Posted: 04 Oct 2010 at 2:43am
have two new ones for twenty dollars each plus shiping. email if imterated
