WC Differential
WC7610 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WC7610 Quote  Post ReplyReply Direct Link To This Post Topic: WC Differential
    Posted: 28 Aug 2010 at 10:17am
Hi,
I'm removing the torque tube assembly from the differential to put a new gasket in.  Should this just slide out or is there some type of retainer?
Thanks in advance,
Thanks
MNLonnie View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MNLonnie Quote  Post ReplyReply Direct Link To This Post Posted: 28 Aug 2010 at 10:25am
I believe you need to remove the axles to get that apart, which means opening up the final drives.
TomMN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TomMN Quote  Post ReplyReply Direct Link To This Post Posted: 28 Aug 2010 at 10:52am
Yes, the pinion shafts need to be removed to get that out.  Here is a link to my pictures of what all comes out and what it looks like.
http://home.comcast.net/~old_allis/ac-RC-chassis.html
Post Options Post Options   Thanks (0) Thanks(0)   Quote WC7610 Quote  Post ReplyReply Direct Link To This Post Posted: 28 Aug 2010 at 11:04am
Thanks Guys.
Tom, I went thru your album and and I'm totally in awe of the detail you've put into your restorations.  You definitely set the standard.
Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote MNLonnie Quote  Post ReplyReply Direct Link To This Post Posted: 28 Aug 2010 at 1:35pm
That is a great photo album. I never think to take pictures when I do stuff. Sometimes I wish I did when it's 2 years later and I'm trying to figure out how something goes together.
