Rottary Cutter gear box help needed
twinsonfarm View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote twinsonfarm Quote  Post ReplyReply Direct Link To This Post Topic: Rottary Cutter gear box help needed
    Posted: 19 Jul 2020 at 9:49pm
I have an old Brillion RSS-72 rottary cutter that needs a new gear box.  The bolt pattern is 7 inches x 7 inches  or on a 10 inch circle at the four corners.  I can't find a gear box that would fit.  I only need a 30-50HP gearbox as this is operated with a Allis WD45.  Any suggestion as no one around my area stocks gear boxes.  Jim
JoeM(GA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoeM(GA) Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jul 2020 at 10:23pm
might check with these people -
Allis Express North Georgia
41 WC,48 UC Cane,7-G's,
Ford 345C TLB
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jul 2020 at 10:53pm
depends on what OUTPUT shaft size you need.. I just bought a replacement for a 6 ft mower... 1-3/8 inch round input with shear bolt, and 1.57 inch output shaft with 12 splines slight taper........ this is the STANDARD gear box for most 5-6 ft mowers.... if your OUTPUT is about 1.75 inch, you have the BIGGER BOX..........the bolt pattern on this one is about 7 inch circle. I would cut a 1/4 inch plate and cover your existing hole and mount this new box on the new plate... Cost was about $150..
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jul 2020 at 11:07pm
i doubt that Brillion made the gear box.. There are several "standard" sizes.. you need to know what INPUT shaft size and OUTPUT shaft size you need first...
i bought this for a 6 ft mower we use behind a 60 HP FORD.
wayne IA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wayne IA Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jul 2020 at 12:13am
Jim.ME View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jim.ME Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jul 2020 at 5:31am
You might check with http://www.dnequipment.com/store/pc/viewBrands.asp .  It may be best to call them if you don't see it on line.
