Hand sanitizer |
Post Reply ![]() |
Author | ||
steve(ill) ![]() Orange Level Access ![]() ![]() Joined: 11 Sep 2009 Location: illinois Points: 88421 |
![]() ![]() ![]() ![]() ![]() Posted: 13 Jul 2020 at 8:34pm |
FDA says MOST of the hand sanitizer coming from Mexico contains METHANOL instead of ETHANOL.... and the labels are Marked WRONG..
If your sanitizer was packaged in Mexico-- throw it away !!! These 9 hand sanitizers may be toxic, FDA warns |
Sponsored Links | ||
DMiller ![]() Orange Level Access ![]() Joined: 14 Sep 2009 Location: Hermann, Mo Points: 34283 |
These people are IDIOTS Steve. Sanitizer can be Ethyl alcohol(Grain distilled) or Methyl(Methanol) alcohol based, gets put ON the hands and evaporates, only toxicity is if try to drink it as the old alcoholics used to drink Mouthwash for the alcohol(Ethyl based). No different than using rubbing alcohol on the body(Methyl or Methanol)
When they distill drinking alcohol the first stuff and the last stuff off the stills(Heads and Tails) is primarily Methanol based, the sweet stuff we drink is in between the heads and tails!!! Whiskey companies sell the stuff they cannot use for medicinal purposes(Methanol) |
Tbone95 ![]() Orange Level Access ![]() ![]() Joined: 31 Aug 2012 Location: Michigan Points: 12243 |
Yep.....all except, rubbing alcohol is Isopropyl. |
Brian F(IL) ![]() Orange Level Access ![]() ![]() Joined: 14 Sep 2009 Location: Paxton, IL Points: 2720 |
My wife mixed up a concoction from a recipe she found. Uses aloe and Everclear (alcohol I bought at the liquor store). And, no, I don't drink it.
Everclear. . .
![]() ![]() I drank it. Once! |
chaskaduo ![]() Orange Level ![]() Joined: 26 Nov 2016 Location: Twin Cities Points: 5200 |
Solvents absorb easily through your skin and into your blood stream. Some people are real sensitive to stuff and react right off, while others seem indestructible till they drop.
good point chas |
YEA, im not a chemist.. dont play one on TV either... Just pointing out that the FDA says it is not a GOOD idea to spread METHanole on your skin... and i agree, DONT DRINK IT !
Any and every alcohol is a solvent including those we drink, makes no difference what type is in sanitizer, the issue was mislabeling NOT the alcohol as the drunks could possibly drink the stuff and die.
LouSWPA ![]() Orange Level Access ![]() ![]() Joined: 11 Sep 2009 Location: Clinton, Pa Points: 25296 |
Mix it with grape juice concentrate....man you got a good time there! It is, however, not a free ride, you will pay in the morning! Oh the days of my misspent youth!
I am still confident of this;
I will see the goodness of the Lord in the land of the living. Wait for the Lord; be strong and take heart and wait for the Lord. Ps 27 |
Of course it makes a difference! It also makes a difference in the label for drunks, but methanol is more toxic to your body. So you wouldn’t make a sanitizer that’s toxic and absorbs through the skin. Even if it still kills the virus. |
The “Apple Pie” they make has it too. So I guess I’ve had it a couple more times ![]() |
You guys still do not get it. The Methanol tainted alcohols(Heads and Tails) from Distilleries are NOTED as sold for these type products, unusable anywhere else, can be marketed as Grain Ethyl Alcohol but cannot be used for liquor as does contain methanol. That can be looked up.
Post Reply ![]() |
