wd manifold nut torque
Jaybird14 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jaybird14 Quote  Post ReplyReply Direct Link To This Post Topic: wd manifold nut torque
    Posted: 03 Jul 2020 at 2:37pm
Quick question. How many ft pnds to tighten the manifold nuts?
thanks!!
Jay
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sugarmaker Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jul 2020 at 3:00pm
Jay,
 I was thinking 14 to 18 ft lbs. a grade 5 bolt spec is about 23 ft lbs.
dr p View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dr p Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jul 2020 at 9:00pm
I set mine to 25 ft pounds
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jul 2020 at 9:21pm
If it is after market, don't torque two outer nuts very tight. They will break off.        MACK
dr p View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dr p Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jul 2020 at 5:56am
Mack is right about that. And make sure they are straight or you will break the manifold
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jaybird14 Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jul 2020 at 8:11am
thanks for the info guys,
I put on the after market manifold yesterday, after losts of filing and carb stud making. One coat of rustoleom high heat primer and two coats high heat black.
 Started snugging up the new stud nuts evenly from the inside out. I needed to go back and forth a few times seeing as when i snugged one down another loosened a bit. I progressed very slow and deliberate. Then i just fired it up. lol
She ran great sitting still. No smoke.. no fire :)  I ran it until i thought the thermostat opened , shut her down and let cool. I need to add some coolant so i did. that was all there was time for yesterday. Today I will drive it a bit and let you know how that all goes.
HAPPY 4th!!!!
Jay
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jaybird14 Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jul 2020 at 6:52pm
She ran good today but a little hot. I know the coolant is full and i richened up the mixture.
How do I diagnose the status of the water pump? there are no leaks at the pump so i assume its ok???
