New to me 8070
ajl View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ajl Quote  Post ReplyReply Direct Link To This Post Topic: New to me 8070
    Posted: 24 Jun 2020 at 5:03pm
Just bought this 8070 PD tractor a couple weeks ago.  A few questions:  is the serial number that number in the casting just above  and to the right of the pto cover?  Says 2884 there which would make it a 1984 model.  It is a PD and not a power shift unfortunately, and it is hard to shift into high range.  Low range no problem.  Linkage problem?   Everything else works on it including the tach which says 3346 hrs but guys say they are notoriously inaccurate.  uploads/2203/AC2.jpg
Ron(AB) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ron(AB) Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jun 2020 at 6:43pm
Sounds like you have your questions answered already.
How much did it cost?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jun 2020 at 7:29pm
Nice looking tractor, thanks for the pic, yes the serial number is there,  and you need new shifting cables
ajl View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ajl Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jun 2020 at 11:03pm
Got it for CAD 18500
ebowman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ebowman Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jun 2020 at 12:33pm
This got me wondering....... There were approximately 3K of each of these 8000 series tractors built, Does anyone have the number built that are 2 wheel drive verses front wheel assist? i just bought an 8050 and was curious
WD45, '62 D17 Diesel, '65 190XTD, '74 7030, 1958 Roto-Baler
Unit3 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Unit3 Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jun 2020 at 9:25am
AJL, try turning the steering wheel while you are running the range lever. It helps me with the PS trans.
This page was generated in 0.045 seconds.
