Gleaner e
Steve g View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve g Quote  Post ReplyReply Direct Link To This Post Topic: Gleaner e
    Posted: 18 Jun 2020 at 7:15pm
Just picked up a E with a 2 row head.
I see 4 pins that what I believe hold the head on . Large drive belt is off. Am I missing anything else to take head off combine. I see a chain on a sprocket left side next to drive belt does that chain have to come off also.
Calvin Schmidt View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Calvin Schmidt Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jun 2020 at 8:25pm
The four pins are spring loaded. Push (hammer) them in and move into the slot to hold them in.
Took two grain heads off last week.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jun 2020 at 8:49pm
Release two bottom pins, let head down until theirs 2 inch gap at bottom. Set jacks or blocks on each side. Release top pins and back up.      MACK
im4racin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote im4racin Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jun 2020 at 9:04pm
Yes that chain has to come off. The tool on clean grain elevator has a dimple in the end to push the 4 wedge pins in. When you get them pushed in slide down in the slot to hold them in the released position. What is the serial number of your E?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve g Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jun 2020 at 8:43pm
Thanks for the replies not sure of serial number yet been sitting long time at this old boys farm. Got to get it hauled home. Jacked it up out of the ground last week only 1 flat rear tire
ac fleet View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac fleet Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jun 2020 at 3:31pm
I have an E with both heads---also got a book with it for an E III but looks like same machine almost.
DanD View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DanD Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jun 2020 at 6:13pm
E III is same as a K except for the engine.
Post Options Post Options   Thanks (0) Thanks(0)   Quote im4racin Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jun 2020 at 10:37pm
My late E(E19600) is closer to an E3 than an early E.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve g Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jun 2020 at 7:39pm
Pulled top radiator hose very green antifreeze in stat housing and drain plug in radiator came out and again very green water shot out . Will it start
Post Options Post Options   Thanks (0) Thanks(0)   Quote im4racin Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jun 2020 at 9:42pm
Hard to say. One of mine was stored inside all but the last 3 years before I got it. It had stuck valves. Bought an f that was in the pasture for 25 and it started and drove off trailer.
Going to help a friend get a 6600 gas that has been in the weeds for 10 years tomorrow. Hope for the best as he wants to take it to the field this fall!
This page was generated in 0.172 seconds.
