Fall seeding alfalfa
Curt IA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Curt IA Quote  Post ReplyReply Direct Link To This Post Topic: Fall seeding alfalfa
    Posted: 25 Aug 2010 at 9:37pm
Has anybody ever fall seeded alfalfa, I rreplanted my alfalfa field last year it did not take. I am going to reseed this Saturday we'll see how fall seeding does. located in central Iowa.
Curt
AllisFreak MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AllisFreak MN Quote  Post ReplyReply Direct Link To This Post Posted: 25 Aug 2010 at 9:41pm
I just seeded some yesterday. It's the first time I planted late summer alfalfa. We'll see if it survives the Minnesota winter.
Dale H. ECIL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dale H. ECIL Quote  Post ReplyReply Direct Link To This Post Posted: 25 Aug 2010 at 9:42pm
For some reason you CAN NOT reseed alfalfa, You have to plow it up and plant either corn or beans one year, then you can seed back to alfalfa.
Allis Chalmers Museum, Paris, Il.http:// www.allischalmersmuseum.com 217-275-3428
Post Options Post Options   Thanks (0) Thanks(0)   Quote Curt IA Quote  Post ReplyReply Direct Link To This Post Posted: 25 Aug 2010 at 9:55pm
I burnt off the old alfalfa with round-up.
joshjohndeere View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote joshjohndeere Quote  Post ReplyReply Direct Link To This Post Posted: 25 Aug 2010 at 10:07pm
i would have tried reseeding it with a no till drill u can reseed if u do it before u take the first crop off the newly planted alfalfa. we have done it before with decent success.  as far as replanting it now go ahead if u plant it now hopefully it will grow tall anough before it frosts and you will be ok.  the theory of not being able to replant alfalfa into existing alfalfa is mostly true unless u do as i described earlier.
Post Options Post Options   Thanks (0) Thanks(0)   Quote joshjohndeere Quote  Post ReplyReply Direct Link To This Post Posted: 25 Aug 2010 at 10:21pm
oh and by the way if u plant a crop in the field after u break up the alfalfa u dont have to stick to corn or beans, to continue our forage production we plant sudan grass, or sudex, or triticaly ( i think thats how u spell it )  that way we still have or continuing forage source and still have feed for our cattle herd.  oh and by the way if u dont think im very credible dad and i hay roughly 1200 acres of brome and prairie, and 1400 acres of alfalfaif if im not working at john deere or on my allis's im putting up hay...lol
i hope this helps.
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 25 Aug 2010 at 10:29pm
I think killing the alfalfa by tilling or chemicals lets the alfalfa release toxins that won't let new seeds sprout.
Wink
I am a Russian Bot
BrettPhillips View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BrettPhillips Quote  Post ReplyReply Direct Link To This Post Posted: 26 Aug 2010 at 7:14am
Google alfalfa autotoxicity
John (C-IL) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote John (C-IL) Quote  Post ReplyReply Direct Link To This Post Posted: 26 Aug 2010 at 7:40am
It's called aleopathy and new seeding into an established stand will not work. If the previous stand did not work you will probably be okay. If failure means less than 30% you will probably be okay, but skipping a seeding cycle would be the best. I've seen it go both ways, but if you are serious about getting a good stand established it probably isn't worth the risk of missing another cycle.
Here are a few pictures of seeding our Dairyland Alfalfa seed variety plot.
I had to throw in a tractor picture of me rolling in the seed.
Edited by John (C-IL) - 26 Aug 2010 at 7:53am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Curt IA Quote  Post ReplyReply Direct Link To This Post Posted: 26 Aug 2010 at 8:36am
I planted beans in 2008, seeded alfalfa/oats in 2009. A little alfalfa came up don't know what happened but had very little alfalfa this year. Sprayed it with round-up on 8/18/10 will replant alfalfa/orchard grass Saturday
Russ-neia View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Russ-neia Quote  Post ReplyReply Direct Link To This Post Posted: 26 Aug 2010 at 9:17am
It would have been better to have it in the ground before the 10th.  You're in a tight window now, hoping for rain to germinate, then grow enough before it freezes.
Mike NEIN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mike NEIN Quote  Post ReplyReply Direct Link To This Post Posted: 26 Aug 2010 at 10:31am
I've always had better luck seeding in the fall rather than spring. If it don't rain then all you are making is weeds all summer long. The best stand I've got was drilled on October 1, inner seeded with wheat. (Everybody told me it wouldn't work.)
Charlie175 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 26 Aug 2010 at 11:22am
Our stand planted last fall didn't do squat this year, but we did get some nice weeds out of it :(
Charlie
norm [ind] View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote norm [ind] Quote  Post ReplyReply Direct Link To This Post Posted: 26 Aug 2010 at 8:18pm
  good to put in some turnip seed wih the alfalfa   dam they are good an sweet   they   like the alfly seed
Post Options Post Options   Thanks (0) Thanks(0)   Quote Curt IA Quote  Post ReplyReply Direct Link To This Post Posted: 29 Aug 2010 at 10:00pm
Alfalfa was seeded Saturday, I hope I can show some pictures of a green field in a couple weeks, and lots of alfalfa hay next spring
This page was generated in 0.097 seconds.
