301 gas
Carl(NWWI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Carl(NWWI) Quote  Post ReplyReply Direct Link To This Post Topic: 301 gas
    Posted: 08 Jun 2020 at 11:20pm
Have a 190xt frame sitting here I’d like to strip down for farm class. Can’t run turbos below 9500lbs here so was thinking a 6500lbs class with a built 301 gas. Read a few different posts, big carb and diesel pistons machined down. Any simple options for longer stroke? What rods? Larger bore pistons that will work? Will definitely need some head work as well.
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jun 2020 at 6:44am
The simple way to BIG power is to write a BIIIG check LOL Great pullers can either be built or brought Wink
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jun 2020 at 7:12am
Diesel pistons with some machining on the tops to lower the compression a bit is the cheapest and obviously the least effective because the cubic inches are the same. A larger carb helps and then a huge carb with a worked over intake manifold comes next. I have done two 4.500" bore engines. One at 405 cubes with a stock crank and the other at 442 cubes with a stroked crank. All my 4.500" engines are custom made pistons and sleeves and cost $$$$$ to do.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Carl(NWWI) Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jun 2020 at 12:21pm
At 4.5” I’m guessing the block has to be machined? What’s a cylinder kit run for 4.5”?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jun 2020 at 12:25pm
Been about 15 yrs ago since I did my last one. Boring block runs me $900 for 6 holes.  Pistons, sleeves and rings are probably $2800 to $3,000 by now for six.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Carl(NWWI) Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jun 2020 at 7:20pm
Ok, that’s not terrible. If I go that route are you able to get them made for me?
Robacpuller View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Robacpuller Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jun 2020 at 8:38pm
Don't forget cam grind and degreeING the cam.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jun 2020 at 7:01am
I'd have to look and see if I still have my drawings and design specs on those parts. If I do, it shouldn't be a problem. The downside would be they could be months away from completion, like not this Summer for sure.
d17brown View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote d17brown Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jun 2020 at 2:45pm
I have a complete 301 gas engine 350$
phil
bsallis180 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bsallis180 Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jun 2020 at 5:11am
I have a block that fresh from machine shop 100% redone for sale. Also Sleeves. Diesel pistons and if you want hardened rods can go with it and a gas cam. Not to cut The Dr off don’t want to take anything off of him
Post Options Post Options   Thanks (0) Thanks(0)   Quote Carl(NWWI) Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jun 2020 at 9:52pm
Ok, I’m not going to do anything until winter. Just brain storming. Trying to decide between gas or diesel. Only bad part is no turbo classes below 9500. But pretty sure if I build a turbo 301 I could get some pulls to add a 7k or 8k turbo class. Gas would be fun to build. But so would a diesel. Was thinking gas would be cheaper but it would honestly be the same either route. And I already have a flower head with bigger valves for a diesel, so that saves a lot right there.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jun 2020 at 7:37am
When it comes to gas versus diesel without a turbo?? gas will always make more HP  !!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Carl(NWWI) Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jun 2020 at 10:10am
Absolutely! I will either build a gas, or a turbo 301 diesel. I had a diesel before, ran good with what I had done. Should’ve just coughed up the money for an s200 and I would’ve ran great. Tore it down planning on using one of OPS heads over bore kits. But changed my mind, still would have to pull against 1066’s. If I strip one down and build it like I had before I shouldn’t have a problem keeping towards the top.
Edited by Carl(NWWI) - 13 Jun 2020 at 10:13am
frnkeore View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote frnkeore Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jun 2020 at 5:37pm
I have a quick question, maybe :)
What does it take to convert a 301 diesel to gas?
Can you do it with just a head and lower compression pistons?
The reason I ask, is I passed on a 180, last month, because it was a diesel. All my tractors are gas and I don't want to add a diesel.
Frank
1959 D17 Series I #24001+, '59 D14
'55 & '59 Ford 850 & 861
Ferguson TO 35 Deluxe, Oliver 70 and 5 more.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jun 2020 at 6:49pm
The parts list to convert a 180 diesel to a 180 gas would be a long one: pistons and sleeves to a 301 gas engine......cylinder head and valves.....exhaust manifold (which there are none available) ..intake manifold.....distributer, cap and wires......different camshaft.....carburetor.....governor......different timing cover and front plate on the engine......air tube from air cleaner......fuel pump...….and on and on...…….
Post Options Post Options   Thanks (0) Thanks(0)   Quote Carl(NWWI) Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jun 2020 at 12:29am
Sleeves and cam are the same part number according to parts books for diesel and gas. Nevermind. Depends on what page you look at....glad I double checked. Some I’ve found those for aftermarket the G2800 and D2900 sleeves are same part number. Camshaft is definitely different part number tho.
Edited by Carl(NWWI) - 14 Jun 2020 at 12:35am
Post Options Post Options   Thanks (0) Thanks(0)   Quote frnkeore Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jun 2020 at 2:59am
Thank you.
Frank
omahagreg View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote omahagreg Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jun 2020 at 6:16am
My grandpa had a 185 that needed inj pump work again, but he was not crop farming much anymore, but was feeding cattle and wanted a gas tractor with loader. Talked to Wells Implement, Plymouth Nebraska. They took the parts off a combine and converted it to gas with oem parts! Sold him a Westendorf loader with grapple fork and he was smiling ear to ear! Never did hear what it all cost, but it can be done!
Greg Kroeker
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jun 2020 at 6:44am
It can be done with a complete gasoline engine from a model "G" combine, is what they did, utilizing parts from each engine to make it happen. They still had an issue getting the correct timing cover and front plate, as those parts still had to come off of a gas tractor engine.
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jun 2020 at 8:24pm
For a puller engine that the most HP per CID would be desired, I believe that a Spark ignition engine running on E85 or propane would be the best choice. Both fuels would be 105 octane, low cost and a general consumer fuel. Some place have rules against "Racing Gas"
High HP per CID in a diesel means TURBOCHARGINGThumbs Up or NOS (Nitrous Oxide)Thumbs Down
