I400 Reverser
K.Novak View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote K.Novak Quote  Post ReplyReply Direct Link To This Post Topic: I400 Reverser
    Posted: 01 Jun 2020 at 4:30pm
I recently purchased a 1968 I400 with the Reverser transmission. I'm looking for some guidance on how to address a reverser that pops into the neutral position when "free wheeling" only. Under load (going up a grade, pulling, or pushing the bucket into a pile of material) it will hold in either the forward or reverse position; whichever is being used. I realize I will likely have to split the tractor to properly fix this so I'm hoping to acquire some general information and direction on the issue before jumping in. Thanks in advance!
1934 WC SN# 2123,Factory WFE
1935 25-40 SN# 25557, TS
1938 WF SN# 506, Full Steel
1967 I400 SN# 1302
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jun 2020 at 4:40pm
Like every other Allis transmission, worn dogs in the shifting collars from grinding gears.
Gary View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jun 2020 at 8:09pm
In an Allis I40 - Industrial D-12 - the 'Reverser' appears to be separate Gear Box between the Torque Tube and the Transmission.
So wouldn't the Lever be moving a Gear forwards and backwards?
See pictures in attached Ad
https://www.purplewave.com/auction/130814/item/ae9138
Edited by Gary - 04 Jun 2020 at 8:11pm
