HD5G PARTS
JEM49AC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JEM49AC Quote  Post ReplyReply Direct Link To This Post Topic: HD5G PARTS
    Posted: 21 May 2020 at 8:35pm
I purchased a 1949 HD5G last fall. The guy I bought it from got it at an estate sale.
The previous owner pulled the Auburn clutch and sent it out for repair. The engine runs and the hydraulics work. I am just taking inventory of the loose parts that came with it.
Along with the clutch the following parts are missing: both steering levers, shift lever and guide.
I have tried General Gear and Machine, They aren't pulling any parts at this time.
Also I am waiting for an answer from Thill Track and Tractor as they are about a 100 miles from my location in Wisconsin.
Does anyone have these parts available?
Ages Cat View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ages Cat Quote  Post ReplyReply Direct Link To This Post Posted: 22 May 2020 at 7:52am
Contact Doug Quaid @ Northern Tractor in Osseo, MN.
Curt Anderson
HD3, HD5B, HD6AG,HD6B dozer, I-400,615, 616,620,720,ACP25 lift truck, 1956 D Grader, AC 540 loader, AC #84 plow, Simplicity tractors, Agco MT225, Agco 2025,
Gary(WI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary(WI) Quote  Post ReplyReply Direct Link To This Post Posted: 22 May 2020 at 8:37am
Bring your trailer and I will sell you a complete unit for parts Gary 920 253 8192
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary(WI) Quote  Post ReplyReply Direct Link To This Post Posted: 22 May 2020 at 8:38am
Only 2.5 hrs away
Post Options Post Options   Thanks (0) Thanks(0)   Quote JEM49AC Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jun 2020 at 9:44pm
Thanks Curt. I was able to get most of the parts from Doug Quade last week. I talked to you on the phone the other day about the steering levers for the HD5.
I am going to order the available new clutch parts I need from General Gear.
They don't list as available the pressure ring guiding spacer (5) needed. Also the parts book calls out 5/16 NC x 3/4 capscrews. Is that right? Is it possible they should be longer?
Thanks again for your help.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jun 2020 at 10:07pm
Some of the clutch parts may be in stock with Minn-Par in Mpls MN
Unsure if i kept the set of levers I had from parts machine or not - will need to walk out back and check
gemdozer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote gemdozer Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jun 2020 at 6:00am
I am still have some master cluch parts
              gemdozer@hotmail.com
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ages Cat Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jul 2020 at 3:34pm
Regarding the steering levers for an HD5 versus an HD6, the HD5 are both straight. The HD6 has one straight and one curved to allow the opertor to reach between the levers for the throttle.
Curt Anderson
Post Options Post Options   Thanks (0) Thanks(0)   Quote JEM49AC Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jul 2020 at 8:58pm
Thanks Curt. I have been working with gemdozer. He shipped a set of steering levers and some other main clutch parts I needed this morning. Hopefully they will be here by the end of next week. I am currently working on the sheet metal parts that I had laser cut at work. (Fender repair sections that were rusted out under the battery boxes, lids for the battery boxes, new support panels for the seat base and back, new floor sections and inspection plate for main clutch) I have them drawn up in cad to get the parts laser cut. I can provide a pdf to anyone needing any of these parts.
