soaking frozen engine
nickia View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote nickia Quote  Post ReplyReply Direct Link To This Post Topic: soaking frozen engine
    Posted: 20 May 2020 at 12:22pm
what was the formula people are using for soaking a frozen engine acetone and brake fluid?  been soaking with wd-40 but i think i need something with a little more kick to it?
HoughMade View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HoughMade Quote  Post ReplyReply Direct Link To This Post Posted: 20 May 2020 at 1:01pm
If it's rust, skip past grandpappy's mix and go straight to Evapo-Rust.  I tried every other combo for over 2 months on a siezed B, then I tried Evapo-rust and had the engine spinning in a little over 24 hours.  I had the head off, but I suppose it can go in through the spark plug hole.  After 24-48 hours, remove the Evapo-Rust, drain the pan, put some oil in, spray a light oil in the cylinders and crank it over slowly by hand, working it back and forth at first (I used a pipe wrench on the PTO).  In my case it was loose.  Pistons have still never been out and it runs fine with good compression.
Edited by HoughMade - 20 May 2020 at 1:03pm
1951 B
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 20 May 2020 at 1:01pm
acetone and atf   50/50
ac fleet View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac fleet Quote  Post ReplyReply Direct Link To This Post Posted: 20 May 2020 at 1:26pm
oxy/acy torch and a lot of time. --working on a wd-45 right now--2 middle pistons down at bottom of stroke and 2 end ones up---got them loose but NOT the middle ones yet  so its torch time on these. ---got many out that way, be careful how long you heat and use low setting keeping the heat moving around so everything gets heated even.
As to getting them loose without taking the head off---I never found ANYTHING to work!
Post Options Post Options   Thanks (0) Thanks(0)   Quote nickia Quote  Post ReplyReply Direct Link To This Post Posted: 20 May 2020 at 3:49pm
thanks guys!  im hung up on one cylinder soaking with wd 40 for a week now with the back wheel in the air rocking back and fourth  im getting impatient
Rick of HopeIN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rick of HopeIN Quote  Post ReplyReply Direct Link To This Post Posted: 20 May 2020 at 4:13pm
Seems like you should remove head for a look anyway. Then you can spot bad rings, etc.
Most of my experience is with stuck threads and can't say I have not had to finally drill out quite a few of those in the end.
The ATF mix seems popular, I have used that but PB Blaster more often cause its handy. I have tried a lot of different stuff but hard to tell if one is better than the other. Seems like time is the main factor.
I usually try to avoid use the torch as much as possible.
I have a can of Kroil but only use for small jobs cause it is kind of hard to find.
Edited by Rick of HopeIN - 20 May 2020 at 9:54pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote HoughMade Quote  Post ReplyReply Direct Link To This Post Posted: 20 May 2020 at 5:05pm
I agree with this.  It's not that difficult and it makes the whole unsticking the engine thing easier.
1951 B
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 20 May 2020 at 5:11pm
WD-40 is not a penetrating oil.  Might as well pee on it.  The acetone/atf mix works as good as almost anything in a spray can, or better than some.  Good advice, too, on removing the head, then you can see fi water has got in through the exhaust...Wink
tractorboy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tractorboy Quote  Post ReplyReply Direct Link To This Post Posted: 20 May 2020 at 5:43pm
Steve's formula worked for meWink. keith so.va.
Post Options Post Options   Thanks (0) Thanks(0)   Quote nickia Quote  Post ReplyReply Direct Link To This Post Posted: 20 May 2020 at 6:49pm
yes i have the head off  ive done this before with a h-3 and had it freed up in a week by soaking and tapping on the piston with a block of wood and a dead blow each day
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 20 May 2020 at 9:15pm
Acetone and Marvell Merical oil.        MACK
1947WC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 1947WC Quote  Post ReplyReply Direct Link To This Post Posted: 20 May 2020 at 9:18pm
I use JB 80
tomNE View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tomNE Quote  Post ReplyReply Direct Link To This Post Posted: 20 May 2020 at 10:37pm
hydrogen peroxide has out performed anything else that i've tried.  I do believe i tried everything mentioned above!
frnkeore View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote frnkeore Quote  Post ReplyReply Direct Link To This Post Posted: 21 May 2020 at 1:41am
I use Xylene, ATF & Stoddard solvent, equal parts. Xylene penetrates better than acetone.
I pour or heavily spay it in. If you can see the bottom of the cylinder, what for it to get past the piston and your ready to go.
The hydrogen peroxide sounds interesting, I may try that.
Edited by frnkeore - 21 May 2020 at 1:45am
Frank
1959 D17 Series I #24001+, '59 D14
'55 & '59 Ford 850 & 861
Ferguson TO 35 Deluxe, Oliver 70 and 5 more.
Dick L View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dick L Quote  Post ReplyReply Direct Link To This Post Posted: 21 May 2020 at 7:07am
I normally don't chime in on the stuck engines any more. I have never been able to sit on my hands while some magic potion might work. That is just me and how I was made. After I remove the valve cover and check for stuck valves I then want to see with my eyes every moving part while holding it in my hand. This is what I normally find.
This is my next move.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dick L Quote  Post ReplyReply Direct Link To This Post Posted: 21 May 2020 at 7:23am
More of What you can find when removing the head on a stuck engine that has set for a long time after getting water in thru the exhaust.
pits that are deep enough that the can not be faced.
that will only seal by fixed with new seats.
Edited by Dick L - 21 May 2020 at 7:32am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rick of HopeIN Quote  Post ReplyReply Direct Link To This Post Posted: 21 May 2020 at 8:17am
Seems like the stuff we work on in Midwest tends to look like Dick L shows if ya dig into it.
I think Roger Welsch stories of finding tractors in the weeds that would start right up got everyone speculating. Maybe in Nebraska that works but I suspect it is rare out there also. Of course that was 20 years back too.
allisbred View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote allisbred Quote  Post ReplyReply Direct Link To This Post Posted: 21 May 2020 at 9:21am
Best I have ever used is “Kroil” by Kano. This stuff is not water based! It’s in an orange can so you know it has to be great!
Post Options Post Options   Thanks (0) Thanks(0)   Quote TimNearFortWorth Quote  Post ReplyReply Direct Link To This Post Posted: 21 May 2020 at 9:33am
I did a CA, the infamous "Okie Tractor" and had plenty of time to wait on it and room in the shop. Never knew how much stuff you can stuff under a dormant tractor in the shop over a year or more.
Kroil initially but eventually just pulled the drain plug (no water) and started adding acetone/MM mix until each cylinder full and sure enough, one cylinder held the fluid level up and took a good 2 weeks to exit the pan, the other 3 ran by the rings pretty quick.
No hurry but decided to pull the head and glad I did as that one cylinder had enough scale that even if it ate through it enough to be able to move that piston, was obviously gonna do some damage to rings when it broke free.
If you do it with head off, rotating it will unseat the liners and you likely will be going backwards anyway so they need tabs bolted onto each hole to keep liners in-place if you go that route.
The one cylinder with piston fully down was easy enough to clean up but how much crud made it's way into where it will damage the rings?
She will get a rebuild maybe as new liners will be part of it but I will install the old gasket or a new one at some point and see if I can make her run.
If not rebuilt, may just bolt up a 149 or 160 engine from one of the parts 15 I/II that have running engines, either will make that little CA bark for sure.
Dick Lemon's plan is the best route IMO if you want it to run right.
Worth noting; if freeing up something with dished pistons, gonna take plenty of spraying through the spark plug hole to get enough "juice" down around the entire piston(s) . . . .
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 21 May 2020 at 9:57am
My brother bought a 40 Chev pickup off neighbor around 1973. It had been setting in barn lot for at least 20yrs. Engine stuck but dad soaked it with diesel fuel and before long it freed up and we got it running. That engine sat under a closed hood with an air cleaner and exhaust pipe/muffler. Has to make a huge difference,the "parked" conditions.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dick L Quote  Post ReplyReply Direct Link To This Post Posted: 21 May 2020 at 10:59am
Your correct, it makes a big difference if water has not got into and engine. It is also a different reason for it to be stuck. A tractor that has never been exposed to setting outside is a total different story. In the early 1960's I freed up a 1938 Chevy 1 1/2 ton truck and hauled grain with it. I just used motor oil in the cylinders and freed up a couple valves using motor oil while pushing them down and pulling them up until they were free. It only took over night with the oil in the cylinders until they broke free using a screwdriver on the flywheel teeth.
Edited by Dick L - 21 May 2020 at 10:59am
Post Options Post Options   Thanks (0) Thanks(0)   Quote HoughMade Quote  Post ReplyReply Direct Link To This Post Posted: 21 May 2020 at 11:01am
The point about how it sat is a good one.
If rain went into the cylinders and sat there for years...good luck.
Mine was in the humid basement of a barn, but otherwise closed up.  Cylinders 2 and 3 had valves open enough that they rusted.  As I said above, Evapo-Rust worked great.
1951 B
alan-nj View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote alan-nj Quote  Post ReplyReply Direct Link To This Post Posted: 21 May 2020 at 12:54pm
won't that make the tractor a bleached blonde?
If ignorance is bliss, than happy days are here again.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 21 May 2020 at 5:28pm
MMO IS atf!  Back in college, had an auto shop teacher who tested it!  Can't remember which formulation, but definitely atf!Wink
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rick of HopeIN Quote  Post ReplyReply Direct Link To This Post Posted: 21 May 2020 at 8:02pm
I think ATF does most of the work in the formula I tried. The acetone was probably to allow it to soak in better. That is the advantage of Kroil, it is really thin, even kinda smells good.
Edited by Rick of HopeIN - 21 May 2020 at 8:04pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote TimNearFortWorth Quote  Post ReplyReply Direct Link To This Post Posted: 22 May 2020 at 9:16am
With the head off and adding the acetone/MM mix I could see it "swirl" and work, it actually "moved" for a couple minutes.
It does separate so shake the mix well before adding and IMO, the MM Oil is a good "carrier" that does the lube work while the acetone helps break down the corrosion by getting into smaller gaps.
MM oil also has the added benefit of not letting it rust in my case, since mine has been sitting forever with the block full and I wonder what the "mix" has done to bearing areas and seals . . . . .
