Not sure who else to ask...
Buckyman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Buckyman Quote  Post ReplyReply Direct Link To This Post Topic: Not sure who else to ask...
    Posted: 05 May 2020 at 10:48pm
I've been looking and looking trying to learn about a manure pump(like the patz 1512) since my dad has used one for years and I would like to put one in my barn so i don't have to haul every day and all the management associated with that. Dad had a badger bn122 pump which seems to not exist on the internet and the patz pump is the only new one like it that I've found...does anyone know what it would cost to install such a machine?? Anyone know of other companies still making them??
Tenn allis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tenn allis Quote  Post ReplyReply Direct Link To This Post Posted: 06 May 2020 at 5:29am
Never used a piston pump like that before always used a propeller type pump. Company such as GEA or jamesway still make them I’m sure. There is a company called N-Tech that might make a pump like that. Google any of them and get some contact information
Post Options Post Options   Thanks (0) Thanks(0)   Quote Buckyman Quote  Post ReplyReply Direct Link To This Post Posted: 06 May 2020 at 12:55pm
This pump is designed to go inside the barn and "flush" slurry manure out of the tank it has and through a big plastic pipe into a manure pit. Apparently they were popular in "mole hill" systems as my grandpa has said before. That's where someone who would usually haul daily pours a cement pad outside the barn and uses this pump to push manure and bedding up through a hole in the center of the pad to make their manure pile instead of hauling it every day or physically hauling manure out to a pile. I'm willing to bet almost nobody knows what these are cuz my dad is one of two people that I know that has one and the other guy I'm not even sure if he has the same type of pump...
Stacik View Drop Down
Bronze Level Access
Bronze Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stacik Quote  Post ReplyReply Direct Link To This Post Posted: 06 May 2020 at 7:13pm
Tech makes a piston pump but the ones I like are made by Zabel they use a hydraulic cylinder instead of a gear box.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 06 May 2020 at 7:35pm
I worked at a Electrical Power PLant with a coal ash pond.. WE had SLURRY pumps that were electric or hydraulic operated. The PUMP was an impeller type pump. The could pump 50% solids as long as some water was present. They would pump chunks / rocks up to 2 inches in diameter.... You might consider that.....  I saw one  hanging on the bucket of an excavator once... They lowered it slowly into a ash pond with 6 inches of water on top. It ate a hole 2 ft in diameter and 10 ft deep in a couple minutes... look up SLURRY PUMP.
TGerber View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TGerber Quote  Post ReplyReply Direct Link To This Post Posted: 06 May 2020 at 8:24pm
Check out Houle Magnum manure pumps by GEA-lots in our area- good pumps from what I've heard.
DanWi View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DanWi Quote  Post ReplyReply Direct Link To This Post Posted: 06 May 2020 at 10:10pm
Anybody that had a slurrystore had some kind of pump. Sand bedding and pumps are not a good combination. If I was doing something like that I would try to stay above ground when that stuff quits working maintenance is expensive.
JC-WI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JC-WI Quote  Post ReplyReply Direct Link To This Post Posted: 06 May 2020 at 11:29pm
Buckyman, there were only two that I seen in our area,  Patz and Nesseth. Googled Patz... Built in Pound WI.
to much other stuff involved... imo
N-Tech pumps... Built in Barron WI.
Fellow built his pit on a sidehill back in the 1970's, short distance from the barn and used a 40 foot extended chute to run the manure out to the pit... agitated the manure for a few days and then had a gate an the low bottom corner and flowed the manure into the tanker... guess it worked pretty good, was there (and still is) until the family decided to quit milking about 6 years ago.
The hydraulic unites usually are down in a pit...where bad gases can collect. Mechanicals are at ground level.
Seen where a fellow moved heifers into a barn during the winter and started the system up... and 5 months later, the owner of the property had an auction and there was a sight to see, huge slabs of cement laid on top the manure piles. The end of the outlet had frozen and let the manure lift the cement up.
