7040 Battery Cables
Red Bank View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Red Bank Quote  Post ReplyReply Direct Link To This Post Topic: 7040 Battery Cables
    Posted: 01 May 2020 at 10:49pm
I am going to install two 1100 cca batteries and make battery cables for them. What size should I go with? I have plenty of 2/0 cable but should I go larger?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 01 May 2020 at 10:55pm
I always use the original 4-battery cables cut to length for 2 batteries. Two batteries....two big cables.
Alvin M View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alvin M Quote  Post ReplyReply Direct Link To This Post Posted: 02 May 2020 at 6:18am
I Make Mine All Out Of 2/0 Fine Wire Copper Welding Cable
Boss Man View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Boss Man Quote  Post ReplyReply Direct Link To This Post Posted: 02 May 2020 at 6:40am
2/0 should be big enough
rw View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote rw Quote  Post ReplyReply Direct Link To This Post Posted: 02 May 2020 at 6:46am
I use stud top group 31 batteries.  I think the eyelet and stud is less trouble than the clamp and post set up that came from the factory. There are charts on the www that will tell cable gauge needed for the length and amps on the circuit.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 02 May 2020 at 7:38am
2/0 should be fine to carry the current I'm thinkin'.
Steve@B&B
