UC high crop
Jackie751@juno.com View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jackie751@juno.com Quote  Post ReplyReply Direct Link To This Post Topic: UC high crop
    Posted: 30 Apr 2020 at 10:09am
Looking at a uc high crop can you find parts for those and how many were made got some set up on it that it drives back ward like a fork lift and a hydraulic pump of the front any ideas I will try to get pics thanks
JoeM(GA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoeM(GA) Quote  Post ReplyReply Direct Link To This Post Posted: 30 Apr 2020 at 11:57am
sounds like a UC Thompson cane harvester
Allis Express North Georgia
41 WC,48 UC Cane,7-G's,
Ford 345C TLB
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jackie751@juno.com Quote  Post ReplyReply Direct Link To This Post Posted: 30 Apr 2020 at 2:09pm
that is what it is can you find parts for them ? Going to try and put a pic on
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jackie751@juno.com Quote  Post ReplyReply Direct Link To This Post Posted: 30 Apr 2020 at 2:14pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jackie751@juno.com Quote  Post ReplyReply Direct Link To This Post Posted: 30 Apr 2020 at 2:19pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jackie751@juno.com Quote  Post ReplyReply Direct Link To This Post Posted: 30 Apr 2020 at 2:30pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoeM(GA) Quote  Post ReplyReply Direct Link To This Post Posted: 30 Apr 2020 at 5:09pm
UC parts can be found used, Thompson parts will take more looking, things built special for the reverse steering and such, might be some work, there are those on here who cater to the high crops more than others who can guide you more
Ford 345C TLB
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jackie751@juno.com Quote  Post ReplyReply Direct Link To This Post Posted: 30 Apr 2020 at 6:35pm
is it worth 600
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jackie751@juno.com Quote  Post ReplyReply Direct Link To This Post Posted: 30 Apr 2020 at 6:36pm
could you just covert it to a normal high crop
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jackie751@juno.com Quote  Post ReplyReply Direct Link To This Post Posted: 30 Apr 2020 at 9:13pm
he already sold it thanks
nowaktj View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote nowaktj Quote  Post ReplyReply Direct Link To This Post Posted: 04 May 2020 at 4:50pm
Hi Guys-I ended up picking up this unit plus another one from him.
It appears there are major design differences between the two even though the tractor serial numbers are not that far apart (S/N 5471 & S/N 63188 (??)...this might be an error).
Anyway, I am interested to know is someone has some of the cane apparatus for the older or newer one as I would like to make it complete (possibly someone who took off the apparatus to make a straight high crop).   Please let me know...thanks.
D19D, D17D, WD, WC, Snobee, #83 Plow, SC Blade, 14' disk, 400 series planter, B , Terra Tiger, M Dozer w/Baker Blade, TL-12, 42S Grader, G
Richardmo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Richardmo Quote  Post ReplyReply Direct Link To This Post Posted: 04 May 2020 at 5:15pm
what motor is in the one on the back?
Allis ship UC components to Thomson, I believe it was till 1964.
Post Options Post Options   Thanks (0) Thanks(0)   Quote nowaktj Quote  Post ReplyReply Direct Link To This Post Posted: 04 May 2020 at 5:23pm
They are both um engines.   Neither one is stuck!
lowell66dart View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote lowell66dart Quote  Post ReplyReply Direct Link To This Post Posted: 05 May 2020 at 7:47am
The one on the back of the trailer has Thomson cast wheels but that doesn't mean they are original. Should have casting marks on wheels and front axle.
I'll keep an eye out for a loader for you.
AC 6080 (8030,7060,200,175,D-17HC, 6040,160,6140 all gone) Farmall 1066 & 656 Hi-Clear (for sale), White 2-62 High Clearance, JD 4255 Hi Clear.
Post Options Post Options   Thanks (0) Thanks(0)   Quote nowaktj Quote  Post ReplyReply Direct Link To This Post Posted: 09 May 2020 at 6:22am
Thanks Lowell.   I would really like to put the "full" loader on one of these.
Here are some more pictures.
Here is another sideshot of the pair.
Both the old and new one has 21" front tires with the Thomson casting name.  However, the older one is retained by 3 studs while the newer one has 5-6 lug bolts.
Older one has a front beam that looks more like an inverted V.   Newer one is shown below.
Older one has F&H rear cast centers and 36" tires.   The newer one has Thomson centers and 38" tires.
Platforms...amazing differences.   Older one has lever brakes and steering is controlled through linkage to a valve behind the operator.   The newer one has an orbitrol and clutch/brake pedals
Edited by nowaktj - 09 May 2020 at 6:23am
Post Options Post Options   Thanks (0) Thanks(0)   Quote lowell66dart Quote  Post ReplyReply Direct Link To This Post Posted: 09 May 2020 at 8:25am
 UC's had 3 lugs. For 21 inch tires you are only going to find Ford Model A car tires.
