d-14 voltage regulater
tractorboy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tractorboy Quote  Post ReplyReply Direct Link To This Post Topic: d-14 voltage regulater
    Posted: 25 Apr 2020 at 3:10pm
I took the mounting bolts out to move the voltage regulator to access the starter last week . I got starter rebuilt & put back in now it wont charge at all [Batt reading 12.54 volts while running]I seem to have slight stray voltage on the mounting tabs which I don't understand since they appear to be isolated in rubber. I didn't remove any wires going to the regulater & they are all tight. maybe it needs to be"'flashed" , but I 'm not sure how to do this since this tractor is still very original, POSITIVE GROUND.   thanks, keith so va
Alvin M View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alvin M Quote  Post ReplyReply Direct Link To This Post Posted: 25 Apr 2020 at 3:51pm
Regulator Must Be Grounded To Work
Post Options Post Options   Thanks (0) Thanks(0)   Quote tractorboy Quote  Post ReplyReply Direct Link To This Post Posted: 25 Apr 2020 at 4:14pm
By "grounded" do you mean the mounting tabs??
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alvin M Quote  Post ReplyReply Direct Link To This Post Posted: 25 Apr 2020 at 4:35pm
Yes  It Also Has A Wire From Reg To Mt Taps Make Sure That It Sill There
Post Options Post Options   Thanks (0) Thanks(0)   Quote tractorboy Quote  Post ReplyReply Direct Link To This Post Posted: 25 Apr 2020 at 4:48pm
ok thanks !
