D 12 Manifold installation
Tyee II View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tyee II Quote  Post ReplyReply Direct Link To This Post Topic: D 12 Manifold installation
    Posted: 09 Apr 2020 at 9:26pm
I am ready to put my D 12 manifold back together and would like to know a what is recommended to use as a sealant on the 2 studs that enter the cooling passage ? I am thinking anti seize on the remainder of the studs ? New studs, brass nuts  should I be using lock washers alone ( that is what it had previously ) should there be a flat washer between the lock washer and the manifold ? Is there a recommended torque for these ?
Tightening pattern using center out sequence ? Thanks for any info you can provide.
Ed (Ont) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ed (Ont) Quote  Post ReplyReply Direct Link To This Post Posted: 09 Apr 2020 at 9:34pm
Use permatex number 2 on the ones that go into coolant or oil. That’s what it is for.
This page was generated in 0.085 seconds.
