B Governor - which is which?
MikeSMN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MikeSMN Quote  Post ReplyReply Direct Link To This Post Topic: B Governor - which is which?
    Posted: 21 Aug 2010 at 2:46pm
Would you tend to say that this B has a distributor rather than a magneto?
So I ordered the governor for a distributor (right) and should have ordered the governor for the magneto, (left), correct?  Just verifying that the governor on the left is for a "magneto".
wkpoor View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wkpoor Quote  Post ReplyReply Direct Link To This Post Posted: 21 Aug 2010 at 3:01pm
I would more than tend to say. It does have a distributor. I'm a newby to to B's but since mags were common on them it seems also common to see the Delco distrib since it would bolt right up to a mag drive. Looks like a 12V convert too with the ballast resistor.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MikeSMN Quote  Post ReplyReply Direct Link To This Post Posted: 21 Aug 2010 at 3:10pm
Thanks guys - time for a return and reorder!
Dick L View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dick L Quote  Post ReplyReply Direct Link To This Post Posted: 21 Aug 2010 at 3:15pm
That is an after market distributor. That after market distributor was used on several brands of tractors. It does take the same governor assembly as the magneto as it was a direct replacement for the magneto. I was afraid of that from your earlier questions.
