1950 B governor weights/pins
cdsloop View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cdsloop Quote  Post ReplyReply Direct Link To This Post Topic: 1950 B governor weights/pins
    Posted: 12 Mar 2020 at 11:57pm
I'm continuing to work on refurbishing my 1950 B. It's currently in a state of disassembly, and I am working on miscellaneous things while my machinist cousin repairs the manifold. The pivot shaft for the throttle was frozen, so I removed the governor cover to get it freed up, which was successful. With the cover off, I discovered that the pins for the weights are severely worn. The pivot hole in the gear seems ok. Is there anyone that offers just the pins and weights, or just the pins? I'm trying to keep this on a shoestring budget. I see several vendors offer the pins and weights separately for the D series, but none seem to do that for the B/C, only complete governor assemblies. Can someone point me in the right direction? Thanks.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 13 Mar 2020 at 7:45am
Your Agco dealer should have them.        MACK
Gerald J. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 13 Mar 2020 at 9:15pm
Albert View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Albert Quote  Post ReplyReply Direct Link To This Post Posted: 13 Mar 2020 at 9:23pm
PM sent we can help you out
This page was generated in 0.056 seconds.
