AC B questions
BraedonAllisB View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BraedonAllisB Quote  Post ReplyReply Direct Link To This Post Topic: AC B questions
    Posted: 12 Mar 2020 at 6:11pm
i am having troubles with installing a new sediment bowl om my AC B, what should i do...here is a video on my problems....https://youtu.be/7tDSiaQcyKU
thanks in advanceWink
1940 B
19__ WD
Grayray View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Grayray Quote  Post ReplyReply Direct Link To This Post Posted: 12 Mar 2020 at 6:39pm
[TUBE]7tDSiaQcyKU[/TUBE]
Boss Man View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Boss Man Quote  Post ReplyReply Direct Link To This Post Posted: 12 Mar 2020 at 9:35pm
You have 2 different style compression fittings. The new fitting looks like an IH style fitting. What happened to the compression adapter fitting that was in the old sediment bowl?
Eric B View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eric B Quote  Post ReplyReply Direct Link To This Post Posted: 13 Mar 2020 at 12:39am
I would recommend you to remove the other end of the gas line from the carb, then take the gas line and your new sediment bowl into O'Reilly's right there in Lynden and ask the parts man to help you with matching up the correct fittings. I used to deal with them before I moved from the area but I found them to be helpful. Be sure to use teflon sealer or tape or other trusted sealer for the threads on the gasoline fittings. I wish you success, you've got a nice tractor Smile
Dick L View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dick L Quote  Post ReplyReply Direct Link To This Post Posted: 13 Mar 2020 at 6:10am
This fitting goes in the tank first that the sediment bowel then screws into.
Edited by Dick L - 13 Mar 2020 at 6:12am
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 13 Mar 2020 at 6:41am
These are the correct OEM fittings.
ac fleet View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac fleet Quote  Post ReplyReply Direct Link To This Post Posted: 13 Mar 2020 at 12:20pm
I never seen a fitting like that before!---All of mine screw directly into the tank! ----interesting ! LOL!!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote BraedonAllisB Quote  Post ReplyReply Direct Link To This Post Posted: 13 Mar 2020 at 12:47pm
Well thanks for the help, I'll head to O'Riley's and see, I also got a plan to try in my head here, will let y'all know what happens
1940 B
19__ WD
Gerald J. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 13 Mar 2020 at 9:13pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eric B Quote  Post ReplyReply Direct Link To This Post Posted: 14 Mar 2020 at 12:52pm
Originally posted by Gerald J. Gerald J. wrote:
Might be covered in the shop manual.
http://geraldj.networkiowa.com/Trees/Allis-Chalmers-G-B-C-CA-Service.pdf
Gerald J.
Great link! Thanks for posting it! Clap
