Generator 6 to 12 volt conversion
WEL(TN) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WEL(TN) Quote  Post ReplyReply Direct Link To This Post Topic: Generator 6 to 12 volt conversion
    Posted: 03 Mar 2020 at 12:21pm
I have a 56 AC CA that has a 6 volt generator that was converted to 12 volt. It works ok but its putting out 18 volts instead of around 14 volts. Is there anything I can put in line (generator to amp gauge) to cut the voltage down to 14 volts?
AaronSEIA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AaronSEIA Quote  Post ReplyReply Direct Link To This Post Posted: 03 Mar 2020 at 12:33pm
Voltage regulator?
AaronSEIA
Post Options Post Options   Thanks (0) Thanks(0)   Quote WEL(TN) Quote  Post ReplyReply Direct Link To This Post Posted: 03 Mar 2020 at 12:47pm
It has a universal cut out on it which is new. No adjustment.
Fred in Pa View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fred in Pa Quote  Post ReplyReply Direct Link To This Post Posted: 03 Mar 2020 at 1:07pm
 Yes a correct Regulator . take  generator back  to that shop and have them match one up .
Edited by Fred in Pa - 03 Mar 2020 at 1:07pm
nonetheless ,still dead.
Alvin M View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alvin M Quote  Post ReplyReply Direct Link To This Post Posted: 03 Mar 2020 at 1:41pm
What Is Your Field Wire Hooked To
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 03 Mar 2020 at 8:19pm
it would not be uncommon for the generator to put out 18 volts or more without a REGULATOR to control it.  I use to go to Auto Zone and just get on for a  1968 chevy pickup ..... pretty standard.
