200 Camshaft gas vs diesel |
Post Reply |
WLHD21
Bronze Level Joined: 06 Feb 2019 Location: Iowa Points: 155 |
Posted: 13 Feb 2020 at 7:37am |
I am working on 200 that has cupped lifters and cam lobes that vary by 0.035”, I have a 301 gas from gleaner G. Before I tear it down does anyone know if there different, I would assume they are, but I’ll ask the experts. Thanks ,
injpumpEd
Orange Level Access Joined: 13 Sep 2009 Location: Walnut IL Points: 4862 |
I would think the valve opening and closing events would be different from a gas to diesel. A quick look on agco parts books shows they are different part numbers, but don't know exactly what is different.
DrAllis
Orange Level Access Joined: 12 Sep 2009 Points: 20192 |
The gas camshaft surely doesn't have the 4 inch long bolt in the nose to prevent camshaft breaking.
Brian Jasper co. Ia
Orange Level Joined: 11 Sep 2009 Location: Prairie City Ia Points: 10508 |
My D17D has a gas cam in it. Sounds like you better find the exact cam like Dr A is talking about though.
MACK
Orange Level Joined: 17 Nov 2009 Points: 7664 |
I have heard of guys putting 262 gas cam in 262D, making them run better. MACK
tbran
Orange Level Joined: 14 Sep 2009 Location: Paris Tn Points: 3285 |
They will interchange - but you are going backward - the gas cam on the intake only had a lift of .355 whereas the diesel was .4405 exhaust was about the same - I can't find the specs now but the gas timing and duration was a few degrees different. They were ground out of the same casting.
The 2000 gas engineering had economy as an objective , the 2500 265 was the cubic inch amount in gas version to match the diesel in hp but the low #'s were a killer in cost for pistons sleeves and cranks.
WLHD21
Did the 301 gas engines in the XT’s have the bolt in the cam shaft?
MACK
301 gas cam never had a bolt in the end. MACK
Post Reply | |
