|  | This site is not affiliated with AGCO Inc., Duluth GA., Allis-Chalmers Co., Milwaukee, WI., or any surviving or related corporate entity. All trademarks remain the property of their respective owners. All information presented herein should be considered the result of an un-moderated public forum with no responsibility for its accuracy or usability assumed by the users and sponsors of this site or any corporate entity. | |||||
| 270 New holland Baler question |
| Post Reply   |
| Lonn   Orange Level     Joined: 16 Sep 2009 Location: Назарово,Russia Points: 29817 |  Post Options  Thanks(0)  Quote  Reply  Topic: 270 New holland Baler question Posted: 19 Aug 2010 at 11:09am |
pull with Series III 190xt so there it's on topic. :-) Anyway, what's the easiest way to remove the pickup? The teeth bars have worn through where the end plate supports them and one broke. Doesn't look like any easy way to remove them. Pulled the set screw under the chamber for the pickup drive shaft. Do you remove the sprocket on the left hand side and pull the whole pickup to the right? Is there another way that I don't see? I think I could have designed the thing better than they did. Surely wasn't Gleaner engineers. Thanks.
 Edited by Lonn - 19 Aug 2010 at 11:09am | |
     -- --- .... .- -- -- .- -.. / .-- .- ... / .- / -- ..- .-. -.. . .-. .. -. --. / -.-. .... .. .-.. -.. / .-. .- .--. .. ... -  Wink I am a Russian Bot | |
| Ed (Ont)   Orange Level     Joined: 08 Nov 2009 Location: New Lowell, Ont Points: 1506 |  Post Options  Thanks(0)  Quote  Reply  Posted: 19 Aug 2010 at 11:48am |
   Don't have the answer but they are a great baler. Spent many hours on a WD45 pulling that baler & a wagon behind. WD45 did a great job & was small enough that it didn't have the wheel on the windrow. Later used a (bad word) MF165 diesel but the WD I thought worked better. 190 might be overkill.
| Lonn   Orange Level     Joined: 16 Sep 2009 Location: Назарово,Russia Points: 29817 |  Post Options  Thanks(0)  Quote  Reply  Posted: 19 Aug 2010 at 12:05pm |
   190 is overkill but it nearly runs on thin air and my wife will drive it where she won't drive my WD or D17.
| bauerd44   Silver Level Access     Joined: 11 Sep 2009 Location: Wentzville, MO Points: 350 |  Post Options  Thanks(0)  Quote  Reply  Posted: 19 Aug 2010 at 3:08pm |
   Lonn, I just did that to a NH273 and it was an interesting experience.  The best thing I can tell you is to go to the following site.
 Go into the Parts & Service tab and Search for Parts.  When the bland window comes up, put your model in the window and search.  Select your baler out of the list and choose the + in front of the Figure listing and you will see the same parts manual the dealer looks at.  Scroll down to the Pickup Group and you will see everything about your baler.   I had to use a gear puller to get apart the one I was working on. PM me with any additional questions. Dale | |
| Lonn   Orange Level     Joined: 16 Sep 2009 Location: Назарово,Russia Points: 29817 |  Post Options  Thanks(0)  Quote  Reply  Posted: 19 Aug 2010 at 4:00pm |
   Thanks Dale.
| Post Reply   | |
| Tweet |
| Forum Jump | Forum Permissions  You cannot post new topics in this forum You cannot reply to topics in this forum You cannot delete your posts in this forum You cannot edit your posts in this forum You cannot create polls in this forum You cannot vote in polls in this forum |
