615 backhoe/D2200 motor teardown question
615_259 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 615_259 Quote  Post ReplyReply Direct Link To This Post Topic: 615 backhoe/D2200 motor teardown question
    Posted: 30 Jan 2020 at 6:28am
In the process of tearing down 2 D2200, both seized and 1 threw #4 rod, and busted the camshaft.
Any tips on removing the cam or crank gear while still on the motor? I cannot rotate the assembly to loosen the cam thrust plate.need to remove the front motor plate to remove the crank.
Second question?
Can the pistons be extracted through the bottom once the crank is out, or can the pistons and sleeve be extracted together?
Top of the sleeves have rust
I read in the service manual that at some point AC switched to hardened timing gears. Will the motor ID plate #s tell the story?
Thanks in advance for any tips and help
Jeff
Edited by 615_259 - 30 Jan 2020 at 6:30am
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jan 2020 at 6:51am
if the cam is busted, anyway, that part is expendable...Wink
Post Options Post Options   Thanks (0) Thanks(0)   Quote 615_259 Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jan 2020 at 6:55am
I would like to try and save the gear
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jan 2020 at 7:02am
Too simple, remove the crankshaft then the cam can be rotated.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 615_259 Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jan 2020 at 7:02am
The front motor plate won't let the crank out with the crank gear on, the front motor plate won't come off without removing the cam thrust plate, one of the gears needs to be removed to allow rotation
Edited by 615_259 - 30 Jan 2020 at 7:08am
drmikeg View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote drmikeg Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jan 2020 at 2:52pm
Wish I had info to help you get crank or cam out. If you don't end up rebuilding one of the motors please PM me as I'm in need of an injection pump for my 615. If I can't find one ill likely be parting out my 615 so might have an otherwise good 2200 minus the injection pump you could pick up in AZ.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jan 2020 at 6:50pm
Can you cut the cam, behind the gear, with a sawzall? Or one of them diamond bone saws?Wink
Post Options Post Options   Thanks (0) Thanks(0)   Quote 615_259 Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jan 2020 at 8:46pm
Thanks for any input
Success. Was able to remove the mains and rod bearings an lift the crank to unleash the gears
Removed the cam thrust plate bolts and everything came apart.
I was able to pop the pistons down a bit to clear up the bores and pull the pistons
Now onto the donor motor
To answer drmikeg, the donor motor did not come with an injector pump, sorry
Best regards to all
Jeff
8070220 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8070220 Quote  Post ReplyReply Direct Link To This Post Posted: 31 Jan 2020 at 6:17pm
U cut the plate the later eng had the plat cut to take cank out whit out pull the plate .right over the crank and cut it some out .
This page was generated in 2.039 seconds.
