Question for Lowell66dart on gear reduction starte
DIESEL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DIESEL Quote  Post ReplyReply Direct Link To This Post Topic: Question for Lowell66dart on gear reduction starte
    Posted: 29 Jan 2020 at 8:15am
I got a gear reduction starter hooked it up and I have nothing. Did you run a seperate ground to the new starter, I figured it would pick up ground through the bolts. Thanks
lowell66dart View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote lowell66dart Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jan 2020 at 9:20am
I ALWAYS run the ground to one of the starter mounting bolts. I don’t have the tractor anymore so I can’t look at the wiring.
AC 6080 (8030,7060,200,175,D-17HC, 6040,160,6140 all gone) Farmall 1066 & 656 Hi-Clear (for sale), White 2-62 High Clearance, JD 4255 Hi Clear.
Post Options Post Options   Thanks (0) Thanks(0)   Quote lowell66dart Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jan 2020 at 9:26am
Do a search here for 7000 series gear reduction starter. It will show you how it’s wired. That big lug on the bottom is the ground lug. From your pics you have it wired wrong
