Piston Question
TMiller/NC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TMiller/NC Quote  Post ReplyReply Direct Link To This Post Topic: Piston Question
    Posted: 13 Jan 2020 at 3:21pm
What is the significance of the "notch" in top of piston?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sugarmaker Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jan 2020 at 3:24pm
Tim,
 My guess is that it faced forward in the tractor??
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jan 2020 at 3:26pm
Maybe points toward front of engine, an 'alignment' mark ??
Hay, it's been a very long while since I was in Grade 9 autoshop !!
now, am I right ? Did I remember something good from highskool ??
Boss Man View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Boss Man Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jan 2020 at 6:45pm
What motor? Usually means that goes towards the front of motor. I remember there being a motor that the rods were clamped offset on the wrist pins and the notch was to make sure the right offset was in the right hole so the wrist pin didn't rub on the sleeve
Post Options Post Options   Thanks (0) Thanks(0)   Quote TMiller/NC Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jan 2020 at 8:32pm
It's a B engine with 3 7/16" liner and pistons...............
I was so happy to get picture posted I forgot to tell engine size...
Thanks, Tim
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jan 2020 at 7:29am
Some pistons have off set wrist pins for a different angel to crankshaft, so notch indicates front of engine.      MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote TMiller/NC Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jan 2020 at 11:20am
Thanks for the replies
Dick L View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dick L Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jan 2020 at 12:30pm
Most notches indicate the oil drain holes in the ring grooves. The notches were not present in the original pistons and I personally have never given there position the slightest attention in this engine. In the slant 6 and the V8 engines I placed the notch or stamped arrow toward the outside.
