200
country2339 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote country2339 Quote  Post ReplyReply Direct Link To This Post Topic: 200
    Posted: 05 Jan 2020 at 3:18pm
bought a 200 for a spare tractor. Having a few issues and this is the first allis I have ever owned. Tractor had a loader on it not hooked up, so i installed missing hoses and hooked it to rear remotes and loader goes up jerking with no load but wont hardly lift a round roll. Have repaired cylinders. What do I check next?
WF owner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jan 2020 at 3:32pm
It sounds like you have air in the hydraulic system. Have you checked the hydraulic fluid level?
Post Options Post Options   Thanks (0) Thanks(0)   Quote country2339 Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jan 2020 at 4:29pm
yes fluid level is showing full
darrel in ND View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote darrel in ND Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jan 2020 at 4:59pm
Are you running an auxiliary valve stack off the tractor remote, or are the tractor remotes running the loader directly? Darrel
Post Options Post Options   Thanks (0) Thanks(0)   Quote country2339 Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jan 2020 at 5:01pm
auxiliary valve
Lynn Marshall View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lynn Marshall Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jan 2020 at 7:07pm
I'm not saying this is the problem, but you wouldn't be the first to not realize that there are two oil fills and dipsticks in the floor by your feet. One takes a half twist to remove and that is the oil fill level for the rear end and transmission. The other one is right there too, but it looks like a large nut and it screws out of the housing. That one is for the hydraulic system and intermediate gears. Both use the same kind of oil. If it's really low on oil, then your steering should be jerky too.
tbran View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tbran Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jan 2020 at 9:26pm
1.  put a load on the three point hitch arms - operate up and down - do THEY hesitate and jerk (this is know as cavitation - the ingestion of air into the hyd flow due to low oil level , leaky supply suction connections , plugged screen in the sump or leaky seal at pump drive shaft or possible oil contaminated with water.  There could be a blown section in the pump allowing recirculation within the pump and low pressure.  These could be the items that need repair. IF the arms lift smoothly and the power steering is smooth, the tractor is fine.
2. IF all above check out - you have crossed lines on the loader or hydraulic tips that are not passing oil thru under pressure.  Hook a disc or other implement and see if it raises correctly.
