A/C HD5G #9552
WaltDevore View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WaltDevore Quote  Post ReplyReply Direct Link To This Post Topic: A/C HD5G #9552
    Posted: 03 Jan 2020 at 6:19pm
Hello Gentlemen,
So look forward to gaining some important advice.  My tractor over the years with me out of the country accumulated water in the muffler through countless freeze thaw cycles.  I cleaned everything up and tried to start it.  It sounded fine turning over but even with starting fluid gave no hint of kicking in.  No doubt the rings are toast.  There is half life on the tracks and sprockets.  Is the engine rebuildable?  I was told it's a 2-72 engine but don't know about that.  I'm in Colorado in the mountains just west of Denver.  Any value in the tractor?  It has both a blade and bucket.  One idler is like new, the other completely worn.  I have an excellent replacement for it, but not skilled enough to install it. There is also a cracked water jacket visible through the muffler side inspection cover.  I have three layers of JB Weld on it.  Don't know if that will do any good.   I sure love the beast.  It made my life for me.  I have many pictures on a facebook page: https://www.facebook.com/Allis-Chalmers-HD5G-109124077151035/?modal=media_composer
Thanks for whatever you can offer!
Edited by WaltDevore - 03 Jan 2020 at 6:23pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jan 2020 at 6:35pm
Is a 2/71 Detroit Diesel, likely the Governor control rack is stuck in OFF or No Fuel. Possibly one of the unit injectors is frozen in the off position and the rack will not allow the other to move. Are covers on the side of the engine opposite the blower, pull those and can see in the cylinders as bar the engine over, can see if really rusted or not.
Simple engines, dry sleeved but is a fitting process to rebuild them replacing sleeves. Pistons have wrist pin seals and MUST be vacuum checked when assembling, no head gasket just seal rings block to head is machined fit, liner height must be within spec or will leak and or blow the liner fire rings. If intent to do this older tools available on fleabay and other sites, a Detroit 71 series engine manual is a MUST Have.
NomoreJohnDeere View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote NomoreJohnDeere Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jan 2020 at 6:38pm
Is it getting fuel?
HD3
Post Options Post Options   Thanks (0) Thanks(0)   Quote WaltDevore Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jan 2020 at 8:18pm
I forgot to add that.  I unhooked the line from the fuel pump and could not get any fuel to come out.  I filled the tank with compressed air to try to push and still nothing.  Mystery as to why the pump isn't pumping.  I back tracked to first filter and fuel was getting that far.  Possibly a plugged line?  I don't quite remember, it's been a few months.
Post Options Post Options   Thanks (0) Thanks(0)   Quote WaltDevore Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jan 2020 at 8:24pm
I  do have the service manual.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jan 2020 at 6:30am
Fuel should flow gravity to the lift pump thru the filters, pull and blow air thru the lines, pull the air box intake off the blower and hand turn the engine see if the blower is rotating. Detroit's are known on older engines with enough set time corrosion to seize a blower and shear the drive splines, that in turn drives the lift pump.
Lee Bradley View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lee Bradley Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jan 2020 at 7:59am
That would also explain it no firing on starting fluid. No air through the engine.
Post Options Post Options   Thanks (0) Thanks(0)   Quote WaltDevore Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jan 2020 at 10:48am
Thank you for the invaluable suggestion.  Would that situation be repairable?
Post Options Post Options   Thanks (1) Thanks(1)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jan 2020 at 10:52am
One 2-71 in a 5B I bought was locked up - seems someone plugged the drain hole in bottom of blower box - water froze andsheared one lobe off one rotor .
 have rebuilt 2 engines complete with just the only special tool needed was height gauge to set injectors . Shimming the liners was a little tedious
 Engine is easily rebuildable - you can check the compression by removing injectors and using a compression gauge with rubber tip into injector tube . Parts are interchangeable with all inline 71 series engines , the V 71 uses a different piston.
 check the air shutoff and governor linkage work and rack is moving when throttle is moved also that air filter is not overfilled so air can't pass through element
Post Options Post Options   Thanks (0) Thanks(0)   Quote WaltDevore Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jan 2020 at 10:53am
I'm not where my tractor is right now.  Can't wait to consult the manual and see how to do it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote WaltDevore Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jan 2020 at 12:41pm
I appreciate the encouragement.  How miraculous to resurrect.  Back to my idler, is it possible to replace the front idler without splitting the track?  The track comes off so easily running it.  I can't quite get it off so far with the side jacked up.  I'd hope to put the new idler on with the adjuster all the way back and use a chain hooked to the track and forward tilt to pull track over new idler.  Is that too optimistic?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jan 2020 at 12:44pm
If rails worn enough have rolled my own off and back on, PITA but better than pounding pins.
dadsdozerhd5b View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dadsdozerhd5b Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jan 2020 at 8:49pm
Looked at your Facebook posts. Engine interior does not look too bad. I double the blower is bad as would have to get water through motor to intake if just the muffler was uncovered. Definitely looks like no fuel getting to it. Get fuel to it, then pull off the intake and put ether there directly. See if you get smoke or an attempt to fire. Drain a small amount of oil out of the pan to be sure none got into the lower end. I have had Detroit’s sit 20 years and can ge them to fire. Easy engine to work on also but may be cheaper to get a complete and swap. Rails on the undercarriage look in good shape, definitely worth the idler swap if you get it running. It is an early one by the serial number. Good luck,
Post Options Post Options   Thanks (0) Thanks(0)   Quote WaltDevore Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jan 2020 at 11:22am
Is it likely that the blower is reparable, maybe a shear pin, or will a replacement need to be scrounged?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jan 2020 at 3:13pm
Blower drives are splined, if locked up the splines shear away in the drive coupler, easy enough to tell if not rotating will need to come off. IF sheared will have to change the Drive coupler(Flat Splined Plate) and shaft. Any decent Detroit Diesel repair parts shop can ID by Engine s/n. Blower is rebuildable and many times are exchange units available. Blower also drives governor.
Edited by DMiller - 05 Jan 2020 at 3:14pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote WaltDevore Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jan 2020 at 3:31pm
Thanks everyone for lighting the darkness for me!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote WaltDevore Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jan 2020 at 12:37pm
I have removed the governor and air pipe, ready to extricate blower.  I don't know where or if to split it at the central assembly or does it all get removed to the front of the engine.  I better not screw this up.  What do you think?  Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote dadsdozerhd5b Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jan 2020 at 1:14pm
Once the intake pipe is removed look at the blower lobes when cranking and see if they are spinning. If so it is not the blower. If not then you have some kind of issue. I have not personally had a blower off but I believe it comes off as an assembly.
Post Options Post Options   Thanks (0) Thanks(0)   Quote WaltDevore Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jan 2020 at 5:17pm
Looks like solid pieces in there.  Do they rotate?  I have no jumper cables right now so can't turn the engine over.  If this rear shaft rotates, will that indicate the blower is good?
Post Options Post Options   Thanks (0) Thanks(0)   Quote WaltDevore Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jan 2020 at 5:19pm
If this shaft is rotating, will that indicate the blower is functional?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jan 2020 at 5:27pm
Looks like you have busted splines or some other foreign material, laying against the bearing.  Maybe its an oil reflection, IDK...Wink
Post Options Post Options   Thanks (0) Thanks(0)   Quote WaltDevore Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jan 2020 at 5:29pm
It's the wire retainer for the ball bearings I think and a little puddle of oil.  If this shaft doesn't turn, is that a bad blower?
Post Options Post Options   Thanks (0) Thanks(0)   Quote NomoreJohnDeere Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jan 2020 at 7:59pm
If you can't turn the splined shaft something is not right
HD3
Post Options Post Options   Thanks (1) Thanks(1)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jan 2020 at 5:59am
Blower sitting on the ground, no governor and nothing else attached should roll with some resistance. Hanging on the engine is still connected to drive coupling. Either corrosion or metal displacement or bad bearing will lock one up, is only .0015 clearance when new lobe to lobe and I did not misplace a 0.
Post Options Post Options   Thanks (0) Thanks(0)   Quote WaltDevore Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jan 2020 at 1:25pm
Well, the shaft rotates with the engine turning over.  I sprayed ether into the air pipe opening and the engine air heater opening.  Zero response.  I guess a compression test is next without the injectors??
Post Options Post Options   Thanks (1) Thanks(1)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jan 2020 at 1:39pm
Valve cover is off? Check the valves, only has Exhaust valve where if stuck open head will need come off.
Post Options Post Options   Thanks (0) Thanks(0)   Quote WaltDevore Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jan 2020 at 1:47pm
It seems the piston rings and valves are next.  My guess.  Can the piston rings be replaced without pulling the engine?  My old 240Z was so easy, drop the pan and remove the head.  These real life mysteries keep the feeling of being alive fresh.
CAL(KS) View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote CAL(KS) Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jan 2020 at 1:53pm
detroit pistons go in from the bottom.
Edited by CAL(KS) - 09 Jan 2020 at 1:55pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote WaltDevore Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jan 2020 at 3:32pm
The action seems to be normal, at least the springs are being compressed and extended.  Seems regardless now, after verifying no compression, to take head off, inspect the cylinders, pull pistons from bottom of engine, replace rings, and new machine?
Post Options Post Options   Thanks (1) Thanks(1)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jan 2020 at 6:46pm
Cannot pull pistons from bottom, pulled as a Set with sleeves and installed same manner. Sleeves are loaded from bottom outside engine.
