D-19 Lift Arms
KenBWisc View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KenBWisc Quote  Post ReplyReply Direct Link To This Post Topic: D-19 Lift Arms
    Posted: 16 Aug 2010 at 2:09pm
I recently bought a D-19 with worn lift arm-rock shaft splines. Because mine are so worn they are nothing to remove however, I just spoke with a guy who said it is almost impossible to separate them when the splines are good. Is this the case? Seems like some soaking and heat and most anything comes apart.
Doesn't the rock shaft just slide out of the housing?
NCAllisnut View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote NCAllisnut Quote  Post ReplyReply Direct Link To This Post Posted: 16 Aug 2010 at 8:39pm
I spent quite a while with a torch, a press, and a big hammer trying to move the arms off of a WD rock shaft, and never got them to budge.
Adam
David(Stockbridge)MI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote David(Stockbridge)MI Quote  Post ReplyReply Direct Link To This Post Posted: 17 Aug 2010 at 6:54am
have a set I bought at albert city along with a pile of other d19 parts, if interested send me a pm.
All "NEW" Web Site http://www.djstractorparts.com
2035,A,U,UC,WF unstyled,WF styled,WC High Crop (cane),RC,B,IB,C,CA,WD,WD45,G,D10,D12,D14,D15,D15 II,D17,D19,WC styled,WC unstyled H3 crawler
skipwelte View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote skipwelte Quote  Post ReplyReply Direct Link To This Post Posted: 17 Aug 2010 at 2:22pm
Seems like D19s dont get as tight as WDs.  They are loose on both my D19s, but not worn real badly in the splines.  Yes, the splined shaft slides out of the housing when one of the arms is removed.  HTH
