D10 - D12 parts wanted |
Post Reply ![]() |
Tracy Martin TN ![]() Orange Level Access ![]() Joined: 11 Sep 2009 Location: Gallatin,TN Points: 10764 |
![]() ![]() ![]() ![]() ![]() Posted: 15 Aug 2010 at 10:09pm |
Looking for the hyd pump intake hose for series II or III. Are the rubber dampners available for the PTO? Thanks Tracy Martin
Dusty MI ![]() Orange Level ![]() ![]() Joined: 13 Sep 2009 Location: Charlotte, Mi Points: 5059 |
Tracy, my local AGCO dealer did a nation wide check for the intake hose for my D-10 seres III, there were none available.
I went to a local NAPA dealer they could get a hose that was similar. My hose had a large split in it. I got a piece of shrink tubing for electrical joints. I also used some Scotch Coat which is a liquid used for water proofing electrical joints. I coated my split hose with the Scotch Coat then put the shrink on and shrink it then applied another coat of Scotch Coat. It's the same story on the dampers. I have 1 in like new condition. I WILL NOT PART WITH IT. I made some out of neoprene. I can make some more. Dusty
Edited by Dusty MI - 16 Aug 2010 at 8:43am |
Dusty, Thanks for your info. I sent you a PM also. Tracy Martin
Bob in King NC ![]() Bronze Level ![]() ![]() Joined: 25 Sep 2009 Location: King NC Points: 2 |
Tracy. if its the hose I'm thinking of. I go to local hyd dealer and get a piece of hyd hose and cut to correct length ,3/4 the best I remember and they sell spring that goes inside to keep from kinking. I have replaced 2 like this and have had no trouble over the past 7 or 8 years. My 2 cents, Bobby in King, NC.
Post Reply ![]() |
