D10 - D12 PTO help? |
Post Reply ![]() |
Tracy Martin TN ![]() Orange Level Access ![]() Joined: 11 Sep 2009 Location: Gallatin,TN Points: 10664 |
![]() ![]() ![]() ![]() ![]() Posted: 15 Aug 2010 at 10:07pm |
What would cause the PTO to run all the time on a series II or III? I can tell the rubber dampner is shot. Would it be warped plates or rubber dampner debris in clutch assembly? Any help appreciated. Thanks Tracy Martin
RMD ![]() Silver Level ![]() ![]() Joined: 07 Oct 2009 Location: Connecticut Points: 300 |
They do that. The PTO clutch runs in oils and the oil gets whirling around inside the clutch housing and causes the driven disk to rotate. They generally won't do that if there is a implement hooked up to the PTO. I believe that Series III had a PTO brake to stop the rotation when the PTO was disengaged. |
Joe/NC ![]() Silver Level ![]() Joined: 11 Sep 2009 Location: Smithfield, NC Points: 265 |
Tracy, on one of mine the PTO "lever" stop is gone, so the lever don't stay all the way in the "brake "position. Actually, just made one and put on it.
Post Reply ![]() |
