Gear Shift Boot Install
Dave (NE) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave (NE) Quote  Post ReplyReply Direct Link To This Post Topic: Gear Shift Boot Install
    Posted: 15 Aug 2010 at 2:43pm
Got a new gear shift boot for the D17 yeaterday at the GOTO.  Am now trying to put it on.  Tried to heat it in boiling water to make it more pliable, but no luck.  Anyone have any good ideas to get these things over the gear shift knob?  Appreciate it.  Dave
Clay View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Clay Quote  Post ReplyReply Direct Link To This Post Posted: 15 Aug 2010 at 3:06pm
Take the rubber gear shift knob off before installing the boot.
Glycerin, tire mounting lubricant, or KY Jelly are good lubricants for rubber components.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave (NE) Quote  Post ReplyReply Direct Link To This Post Posted: 15 Aug 2010 at 3:11pm
How does the knob come off?
Kelly (KS) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kelly (KS) Quote  Post ReplyReply Direct Link To This Post Posted: 15 Aug 2010 at 3:31pm
Dave,
Twist, pull etc to get the rubber shift knob off, then just slide your new boot on.  If I remember right the gear shift has a ball on the end to retain the rubber knob, also might try squirting some lubricant up into the knob from the bottom side.  Hope all is going well in the great state of Nebraska!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave (NE) Quote  Post ReplyReply Direct Link To This Post Posted: 15 Aug 2010 at 7:09pm
Kelly, thanks for the tip.  I wasn't sure you could take the knob off and still get it back on to stay.  Missed seeing you at Albert City.  Get all your hay in?  They said they've had over 32 inches of rain in the Albert City area since July 1st.  It looked like it.  One of the tractors pulling a combine got stuck in a low spot.  But Larry Karg with his four wheel drive 220 got him out!  They had to cut the plowing short it was so wet.
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 15 Aug 2010 at 10:07pm
dishwashing soap works really well for me.
This page was generated in 0.461 seconds.
