CA Rebuild - Engine Compression
Dale (Stonelick) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dale (Stonelick) Quote  Post ReplyReply Direct Link To This Post Topic: CA Rebuild - Engine Compression
    Posted: 25 Nov 2019 at 7:55pm
After putting my 1951 CA back together, it would not start even using starter fluid sprayed into the carb air intake.  The starter works great and it has spark.  Compression is only 15 to 20 psi in each cylinder. Should this be closer to 100 psi?  Should my next step be to replace the piston rings or could the non-starting problem be elsewhere?
The CA did not run when I bought it 21 years ago.  I've worked on the following: unseized the engine,  valve job by machine shop, adjusted valve stem and rocker arm clearance to .012, new manifold and exhaust, converted to 12 volt system (new battery, wiring, coil, spark plug wires, spark plugs [set to .030 gap], new alternator), new electronic ignition and rotor, set the timing, cleaned & refurbed the starter (no new parts), new gaskets, new temp & oil gauges, new oil filter, new gas line and oil tubes.
I rebuilt the carburetor but suspect it still has some problems (e.g. main jet).  However, I was thinking that by using starter fluid, this should bypass carb problems and at least allow the engine to start.  Once I get the engine to start, my plan was to work on the carburetor again.
I did not replace the piston rings or piston sleeves.
Any suggestions will be appreciated.
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 25 Nov 2019 at 7:59pm
That compression is terribly low.  I did a compression test on a D15 on the weekend and I was getting 180-190 psi on all 4 cylinders.
Alberta Phil View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alberta Phil Quote  Post ReplyReply Direct Link To This Post Posted: 25 Nov 2019 at 8:17pm
Have you had the pistons out of the engine or just get them unstuck??  If just unstuck, I would guess that the rings are still stuck in the ring grooves.  You will probably have to remove them and either replace them or at least free them up.  I would vote for replacement if the bore wear is within reason. 15 or 20 psi is too low for the engine to start.  How did you do your compression test?
Engine should be spun over with a good battery and all plugs removed and carb wide open to get an accurate reading.
Dakota Dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dakota Dave Quote  Post ReplyReply Direct Link To This Post Posted: 25 Nov 2019 at 8:47pm
With compression that low it'll never start needs minimum of a 100 psi to run. You could do a leak down test to see if it's rings or valves but with them all about the same I'd bet the rings are stuck to the Pistons. The only sure way to free them up is remove the Pistons and free the rings if you don't break them you can put back in and it will probably run. You could put marvel misery oil in all the cylinders put air pressure on the cylinders as you rotate the engine to try and get between the rings and cylinder walls. Works ok some times if it's only one cylinder. I'd pull the head clean and lap all the valves. if the ring groove is minimal take the rings off clean the ring groove and reinstall. Keep the rod bearings together and reinstall in the same place. Slap a new head gasket on and put it back together.
Edited by Dakota Dave - 25 Nov 2019 at 8:49pm
Gerald J. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 25 Nov 2019 at 9:19pm
The shop manual might help:
http://geraldj.networkiowa.com/Trees/Allis-Chalmers-G-B-C-CA-Service.pdf
Valves not closing completely could kill compression as could very worn cylinders and piston rings.
Gerald J.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 25 Nov 2019 at 9:36pm
If the rings are STUCK, you probably will not get them off the pistons in one piece.. I would pull the pistons and plan on hone and new rings.... if you have the time, you could pull the spark plugs and fill each cylinder with 50% acetone and 50% auto trans fluid and let it set for a month.. crank over and blow all the oil out... then run another compression test....... if the penetrant don't loosen the rings, then its time pull them out..
---------- sometimes a quick test is to put 2 spoon fulls of engine oil in one spark plug hole and then rerun the compression test.. The oil will momentarily fill in the ring gap and raise compression... if that works, you know the rings are the problem.
Ted in NE-OH View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted in NE-OH Quote  Post ReplyReply Direct Link To This Post Posted: 25 Nov 2019 at 9:39pm
Check valve clearance. That is easy to do.
HoughMade View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HoughMade Quote  Post ReplyReply Direct Link To This Post Posted: 25 Nov 2019 at 9:54pm
After checking the valves, if they are OK, put a tablespoon of oil in the cylinders one at a time and re-run the compression test. If the compression come up, it’s the rings. If that’s the case, before a full tear down, I would put Marvel Mystery Oil in the cylinders and let them soak for a few weeks. Yes, a few weeks. As the oil drips past the rings, put more in. After 2 or 3 weeks, drain the crankcase, refill the oil, put a little oil in the cylinders and see if you can get it to start.   If you can get it to run for any length of time, between that and the MMO, you might loosen up the rings. It’s been done. If it doesn’t work, all you lost is a few weeks and the cost of some MMO.
Edited by HoughMade - 25 Nov 2019 at 9:56pm
1951 B
Dick L View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dick L Quote  Post ReplyReply Direct Link To This Post Posted: 26 Nov 2019 at 7:09am
I am sure (if) you have not removed the pistons to check the condition of both the sleeves and pistons that some of the rings are stuck and not expanding to seal the air in the firing chamber. New rings may even not be able to raise the compress to where you get full power. You eyes are never precise enough to know if the piston and sleeves are close enough to spec to reuse. If the sleeves are pitted bad where they were stuck they would always give you problems even it inside diameter is within spec. Without rings and the piston down in the sleeve and you can get a feeler gage of much more than .010 down one side of the piston you will still get blow by out the breather with oil mist. Very hard to adjust a carburetor to solve running problems with low compression.
No way can you guess what condition of pistons, rings or sleeves without measuring in some fashion. A feeler gage, a straight edge, and a flashlight will get you in the ballpark if used correctly, if you do not have access to measuring instruments.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dale (Stonelick) Quote  Post ReplyReply Direct Link To This Post Posted: 27 Nov 2019 at 2:13pm
Thanks for all the input.  I injected MMO in each cylinder and put it under air pressure (used quarter inch black pipe with quick connect on end).  Rec-checked the psi and there is no improvement.  I added some more MMO and will let it still a week and try again later.
When I put each cylinder under pressure, #1 and #4 had alot of air run up and out the oil fill pipe.  This didn't happen on #2 and #3.  Does this indicate a valve problem on #1 and #4?  How do I fix?  Since a machine shop did a valve job on it, I did not expect problems.  I did have some air leakage around the valve cover gasket - I just tightened the nuts until it stopped leaking.
Alberta Phil - I checked compression with a psi gauge attached to quarter inch black pipe insert in spark plug hole, then ran the starter motor.
Dakota Dave - failed the leak down test miserably.  Indicator would fall to zero immediately.
Steve (ill) - the MMO did not momentarily raise the compression.  Does this indicate an unrelated problem (other than the rings), or should I re-test with heavier weight oil?
Ted in NE-OH - How do I check valve clearance, evaluate the results and make needed adjustments?
Everyone - Thanks for all the input.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dick L Quote  Post ReplyReply Direct Link To This Post Posted: 27 Nov 2019 at 2:46pm
Air coming out the oil breather is called blow by. The term blow by means combustion gasses are going by the rings into the oil pan and then out the breather pipe when the cylinder fires. In your case with it not running it is just air. The rings need to be free and lose in the ring groove to have the ability to expand out against the sleeve wall to seal all air and gasses in the firing chamber. I have used seafoam on a running engine to loosen up oil rings to stop smoking over time. Most of the time when all rings on a piston are stuck they have to be pried out in pieces.
If a valve is leaking the air will either come out the exhaust or the carburetor.
Valves clearance will need to be .010 to .012 at top dead center on the compression stroke. I always check with both rocker arms on the same cylinder in the up position. With both rocker arms up both valves are closed so compression can be built. You can turn the pushrods with your fingers at that point as well as insert a feeler gage between the rocker arm pad and the top of the valve.
When a four cylinder engine sets where water can get in thru the exhaust only two cylinder will fill with water and rust fast normally. No way to know the condition of the engine before it was let to get water in.
Edited by Dick L - 27 Nov 2019 at 3:02pm
WF owner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 27 Nov 2019 at 4:05pm
Are you sure the cam is timed correctly with the crankshaft?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sugarmaker Quote  Post ReplyReply Direct Link To This Post Posted: 27 Nov 2019 at 7:06pm
Dale,
Man I wish you had some of these guys standing around your tractor as you are testing things! I am no expert at all. but some things here bother me. some good somme not so good.
Lets see:
 You had the head done by a reputable shop: good
 You have re- assembled the engine? or just got it unstuck and re-assembled the tractor?:   If it was stuck and you had the head off what did the sleevwes look like? Dis you get it unstuck befor or after the head was removed?
Said it never ran when you got it: Well that not good.
As you know They have to have gas, spark and compression, (timing is required to be close too)
 You have set the valve lash to spec: good
 You Have never had it running: well sounds like thats the goal here. we will continue to help until you stop posting and or run out of money! At least that's the way it worked for me on my last WD45 project!:)
 Your compression testing as a static engine with air pressure you would need to have each cylinder with both valves closed for that cylinder. Is that the way you were setting that up?
When you hand crank it (ignition off) does it spin over very very easy with the spark plugs in place?
Sorry for all the questions! Trying to be there with you.
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 28 Nov 2019 at 4:54am
I’ve had a RC tractor that ran with only 30 psi compression. Although it did smoke terribly . If he has carburetor problems, that needs to be addressed before it can run. With either you’ll have either too much or too little fuel to get it to run.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 28 Nov 2019 at 7:31am
It almost sounds like the poor beastie wore itself out.. 15-20 PSI on all 4 cylinders.. then parked.
I'd pull the pistons and sleeves, though I bet 'kits' are $$$$, you've already done the head.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dick L Quote  Post ReplyReply Direct Link To This Post Posted: 28 Nov 2019 at 9:18am
Very true Paul they will run on low compression and will run fair even at 50 pounds with a little smoke. I would venture a guess that his one and four is in the 15 pound range where he has air coming out the breather. Hard to keep a vacuum at the carburetor with compression that low. With the timing firing at the proper time and start well. Lots of details unknown or not understood here.
Edited by Dick L - 28 Nov 2019 at 9:19am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dale (Stonelick) Quote  Post ReplyReply Direct Link To This Post Posted: 28 Nov 2019 at 11:12pm
Dick L: 1-thanks for info on blow by.  Seems to verify problems with piston rings. 2-I had already adjusted the valve stem and rocker arm clearance to .012, but I'll check again if/when I take it apart.  Based on past experience I think the engine should fire even if these aren't adjusted exactly. 3-I bought the tractor 21 years ago and took the head off, had a valve job done, reinstalled the head, and its been stored in the barn since then. If there had been signs of a lot of rust & corrosion in the cylinder heads at that time I probably would have either worked on that problem first or used it as yard art.  My notes from 21 years ago had nothing about rust & corrosion and engine being seized - only that it wouldn't start and a list of replacement parts I needed.  I'm thinking that the engine seized within the last 21 years while under cover. The oil was drained and the oil pan was off during this time which probably didn't help matters. 4- I did adjust the timing (which is another long story).  So I think compression might be the next logical step to address in trying to get the engine to fire.  Let me know your thoughts on suggested next steps.
WF Owner:  A friend and I did set the timing, but do have some lingering concerns.  Since the flywheel did not have a TDC mark and the crankshaft pulley couldn't take the hand crank - I laid under the engine with a flashlight (the oil pan was off) and a friend pushed on the rear wheel in fourth gear until #1 was approximate TDC.  Problem was that we had to turn the distributor about 30 degree counterclock wise to get #1 to line up from where it had been.  If the engine doesn't fire after fixing the ring problem, I'll try moving the distributor back to where it was previously.  My thinking is that the engine should fire (but maybe not run well) even if the timing is off a little.
Sugarmaker: 1- see my #3 comment to Dick L above about sequence of events of seized engine. 2- yes I would like to get it running, so appreciate everyone's help.  3- I tested compression twice with a psi gauge attached to quarter inch black pipe inserted in the spark plug hole and then crank the engine with the starter a few seconds (with gas off).  I did this separately for each cylinder.  The first time I tested I would keep the other three spark plugs inserted.  The second time I tested I kept all the spark plugs removed.  All failed the leak down test miserably. Not sure what you mean by "Your compression testing as a static engine with air pressure you would need to have each cylinder with both valves closed for that cylinder". Can you clarify how I should make this this test. 4-I cannot hand crank my engine, the drive shaft pulley doesn't accept the hand crank.  I can push the tractor in fourth gear, but it takes quite a bit of effort.
jaybmiller:  Replacement pistons/sleeves/rings are about $328 plus tax and shipping.  Replacement rings only are about $50 plus tax and shipping.
ALL:  I currently assume the non-firing problem is caused by low compression due to rusted piston rings.  As suggested by several, I'm soaking the cylinders with Marvel Mystery Oil, trying to loosen these rings up.  Was wondering if a product designed to dissolve rust (like Evapo-Rust) might help.  Any thoughts?
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 29 Nov 2019 at 5:50am
Someone did a test and the BEST stuff was a 50/50 mix of Acetone and Auto Tranny Fluid.
I poured that into 'Troy, my #1 D-14', back in 2000.Kinda stuck from 25+ yrs of sittin. It took 2 weeks of 'fill the cylinders, test to rotate, then wait a day'. Once it would rotate( pipe wrench on PTO shaft), did it 2 more days, then  drained oil,spray brake cleaner into cyls,fresh gas, battery, cough,cough, putt,putt... been fine since.
I'd pull the 'new' head off ,add 50/50 ace/atf, and wait a day...see where the liquid goes.My idea is the acetone allows the ATF to get to all the surfaces and it 'breaks down' the carbon crud and lubes the metals, several applications 'flushes' the crud away, so more is better. just be sure to replace the engine oil before starting !
If she spins nice and still no compression, time to open the wallet and install 'kits'.
Jay
Jim.ME View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jim.ME Quote  Post ReplyReply Direct Link To This Post Posted: 29 Nov 2019 at 6:03am
You have a lot of good help by your side here, follow their advice and you will get it running.
One thing I would suggest is you stop screwing 1/4" NPT nipples into your spark plug holes, before you damage the threads in the head. Either purchase some correct 14 mm to 1/4" pipe adapters or make a couple by welding or brazing a steel pipe nipple to the metal shell of an old spark plug (break and clean all the porcelain out of the shell first). These should also give you a better seal during testing. I'm surprised your compression tester didn't have a 14MM adapter with it, 14 and 18 mm are with most testers. Have you tried your compression tester in an engine, in running condition, to see that there is not a problem with your tester? Is the check valve in it working properly?
When you positioned the engine at #1 TDC to check timing, did you check to see that the valves on #1 were closed (rockers loose, full clearance) and #4 cylinder valves were "on the rock" (no clearance, rockers tight). (I would set the valves at .014 cold as .012 is the hot spec.) Clean the flywheel good when in that position, you may find a faint mark. If not I would at least paint one on it for reference while working on the engine. Rotate the engine clockwise, if your facing the fan, so gear lash doesn't lose a few degrees on you.
Edited by Jim.ME - 29 Nov 2019 at 6:03am
BrianC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BrianC Quote  Post ReplyReply Direct Link To This Post Posted: 29 Nov 2019 at 7:06am
As for the low values on compression, I may be reading comprehension challenged, but it seems to me you made you own compression tester. I didn't see mention of a check valve in your set up. With out that, I would guess the readings would be low, there is no opportunity to "pump-up" on multiple compression strokes.  Why don't you go to Harbor freight and purchase their $30 compression tester.
I think the existing advice for MMO acetone or penetrating oils and time is good.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sugarmaker Quote  Post ReplyReply Direct Link To This Post Posted: 29 Nov 2019 at 8:18am
Dale,
I see that you cant hand crank the engine. To me that is going to make it a challenge to do things like set the valve lash?
I understand the compression test concept but have never taken the time to go get a HF compression tester and do the work.
So do you have a easy way to rotate the engine to bring number one to TDC and see if the # 1 cylinder valves are closed? This would be when you set the valve lash on #1. Then move on to number 2 cyl etc.
I would not tear it apart yet. I would be very surprised that every one of the cylinders have completely stuck rings.  Guess it is possible?
If you have the plugs out and roll it over with your thumb on the spark plug hole does it want to blow your thumb off the hole?
Edited by Sugarmaker - 29 Nov 2019 at 8:20am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dick L Quote  Post ReplyReply Direct Link To This Post Posted: 29 Nov 2019 at 1:34pm
I never tell people to do as I do. When working on an engine I never assume anything. I should say anymore. I have been bit many times in the past by assuming. I tear every thing down to bare bones and work it back together. If I can not see and measure I am afraid of the worse.
If it was here it first would be in little pieces where I could look at the rings. pistons, sleeves and bearings. It could be the reason I have several tractors, cars and trucks in little pieces. I little pieces I know exactly why it is not running.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dale (Stonelick) Quote  Post ReplyReply Direct Link To This Post Posted: 29 Nov 2019 at 2:21pm
Thanks again for everyone's input.
Brian C: Thanks.  I borrowed a "real" compression tester from O'Reilly's Auto Parts and found my compression to be okay.  #1=105, #2=115, #3=105 (with slight leakage) and #4=100.  So, good news is that piston/sleeve/rings should be in good shape, at least enough to let it start.
I rotated the distributor timing back to the original setting (still had rust marks on the distributor base) and tried to fire the engine with starter fluid.  Engine did not try to fire using the electric starter.  It has spark.
Next, I'll try the advise from Jim - ME and Sugarmaker on setting timing and valve stem/rocker arm clearance.  This is difficult to do because the hand crank and pto don't work - I have to push/pull the back wheel while in fourth gear to turn the crankshaft in a controlled manner.
Would appreciate in other ideas on why the engine will not fire.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 29 Nov 2019 at 2:46pm
I wouldn't use starter fluid aka ETHER. I use small size tubing and then 'suck and blow' a 'slug of gas' into the carb body.
You've got compression, spark and gas, so it HAS to be timing.
hmm.. when you say 'spark', doe s that mean ALL 4 plugs have fat blue spark ?
Post Options Post Options   Thanks (0) Thanks(0)   Quote BrianC Quote  Post ReplyReply Direct Link To This Post Posted: 29 Nov 2019 at 3:20pm
Ok, better. My C has 105-115. But 100 is ok to start. And may improve after it runs through some cycles.
The firing order is 1-2-4-3. So that is how you wire up the plug wires. What could be simpler than that?  Hah- are you sure you know which way that distributor rotates?
Pull the cap off and watch while cranking. Wire up accordingly. That one got me on the C with magneto. You would think it would backfire and be all dramatic but it wasn't,  it certainly wouldn't start.
Then once here we had a long thread about #1 at TDC and on the compression stroke.
After all was said and done, it became clear that he had it wired 360 degrees out, I guess sparking on the exhaust stroke.  Wired up right and next post was about success.
As a rough timing mark, the front pulley set screw is built to be at #1 tdc when the screw is pointed straight up. However, I don't want to assume anything- you mentioned that something is not correct with your pulley and or hand crank. Maybe you got oddball parts there. Or no key in the slot.
I predict it will be running very soon.
Edited by BrianC - 29 Nov 2019 at 3:22pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dick L Quote  Post ReplyReply Direct Link To This Post Posted: 29 Nov 2019 at 5:29pm
You might buy one of these and push in the timing inspection hole and spin it with a electric drill while turning the engine over engine over a few times. You might be surprised what might show up.
https://www.ebay.com/itm/DEWALT-DW4902-1-Inch-by-1-4-Inch-High-Performance-Carbon-Knot-Wire-End-Brush-0/163270999215?epid=2254780075&hash=item2603b5bcaf:g:SzwAAOSwjtZbpTGZ
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jim.ME Quote  Post ReplyReply Direct Link To This Post Posted: 29 Nov 2019 at 6:14pm
I second what Dick L suggests, the marks can be hard to find. Get a brush as he suggests. Remove all the plugs. Working through the timing hole in the torque tube, use a a drill to run the brush against the flywheel while spinning the engine over with the starter. Dick can confirm this, but I believe the timing hole on a CA is on the left (setting in the seat), even though the manual says the right side. It may take several tries to clean the flywheel up, but you should find the marks. Then use the valve rock method to locate #1 at TDC and confirm it is on the compression stroke. Also you can carefully use a wire or plastic tube to reach in through the sparkplug hole and touch the piston. You will feel the piston come up (so you can watch for the marks to show in the timing hole), when it stops raising and starts to drop, you went by TDC, again #1 rockers clear of the valves and #4 cylinder valves are on the rock (both tight as exhaust closes and intake opens), will confirm #1 is on the compression stroke.
Normally with all the plugs out and the transmission in neutral one can use the fan to turn the engine, you might have to put some pressure on the belt if it slips.
You said the pto doesn't work. Did you engage the pto using the lever? You might have to turn the shaft a bit while pulling back on the lever to get it to engage.
If you haven't, I would suggest you save a copy of the manual Gerald J. posted to your computer and print off the CA section to have with you in the shop as you work on your tractor.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sugarmaker Quote  Post ReplyReply Direct Link To This Post Posted: 29 Nov 2019 at 7:45pm
Dale,
Well Your doing good and learning too. I always learn something new on these things. Kind of glad that you didnt pull a Dick L and have it all in little pieces yet! Just kidding Dick! I know that is the way to bring them back to good working order!:)
Ok You need to get a better way to turn that engine over easily and safely. If you can jack it up and use the rear tires in gear with out the spark plugs it may work.
How did you rotate the engine to set the valve lash? Your valves must be fairly close or you wouldn't have gotten compression readings.
Yes check the spark at the plugs to assure you have spark. Checking timing mark is good, but if you set the rotor of the distributor pointing at number 1 plug wire when #1 is at TDC, then wire the rest in the 1243 pattern you should be close enough it should pop!
Good you have compression! Nice job getting the tool to check it!
 Now the fuel thing. Do you have gas to the carb? Remove line and check for flow from the tank. Open the bottom of the carb if it has a drain? If not keep taking the carb off or apart apart till you are sure that the bowl is getting gas and all carb components are in place and adjusted. I rarely have to use starting fluid to get one to fire. These guys helped me several years ago on a WD that would not start. Like you I had made many changes.
It lacked fuel. I used a small spray bottle with some gas in it to mist into the open (air) end of the carb. It would run when I misted gas in. Which told me the carb was not working properly. Once that was fixed it fired right up.
Sorry so long winded. Your almost there!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dale (Stonelick) Quote  Post ReplyReply Direct Link To This Post Posted: 30 Nov 2019 at 9:08am
jaybmiller: I used a $9 spark ignition tester (connects to spark plug wire and the plug) and the white light flashed constantly on all four cylinders.  There were no directions for its use, so I'm not sure if it can test for strength of spark.  Do you think I should test them manually to see if it has a fat blue spark?
Brian C: (1) I went out at midnight last night after reading your post to make sure my rotor turns clockwise as described in the manual (it does). (2) to check timing, is it possible to have someone manually rotate the distributor base [after loosening the bolts] while I pull on the starter until we find the correct position for it to fire? (3) my guess it that the hand crank front pulley was replaced with an aftermarket part.  I assume the original broke due to over use of the hand crank - probably wouldn't start for him either.
Dick L: thanks for the wire brush suggestion.  I'll try it when I get someone to help turn the crank shaft.
Jim-ME: (1) Any thoughts on my timing idea on Brian C comment #2 above? (2) with the radiator, fan blades, alternator and water pump installed I found it difficult to turn the crank shaft with the fan belt - but I'll try it again. (3) the pto lever is frozen, but I'll put a pipe wrench on the shaft to see if I can get it to move.  This is on my list on items to work on [after the engine, brakes, hand clutch, hydraulics and new paint] (4) the tractor came with its original manual.  Would be lost without it.  I keep a zerox copy in the barn.
Sugarmaker: (1) just having the tractor torn down in large chunks is a little overwhelming for me (2) I like the idea of jacking up the rear wheels - I'll try it. (3) I set the gap between the push rods and rocker arms when all the front end parts [radiator, fan blades, water pump and alternator] were removed.  I stood on the front end [above the front wheels] and used the fan belt to turn the crank shaft pulley.  While pulling from this height, I had a good view of the rocker arms. (4) any thoughts on my timing idea in Brian C comment #2 above? (5) I did attempt to rebuild the carb, but noticed that there were several potential problems.  For one, the correct main jet seems to be missing - it just had a plug.  I plan to buy a $27 replacement after I get the engine to fire.  If I remove the main jet "plug" with the gas on, gas will flow out the carb. (6) My thinking on spraying starter fluid into the carb air intake [I've removed the air cleaner] to get the engine to fire, is that maybe it circumvents any carb problems.  At this point, I'm just trying to get the engine to fire.  After that I'll work on the carb/throttle/governor and try to get the engine to run.
Today I'll try the idea of jacking up the back axle.  Will appreciate any further  comments/suggestions.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dick L Quote  Post ReplyReply Direct Link To This Post Posted: 30 Nov 2019 at 10:51am
Timing is fairly precise. (All) engines static time at (TDC) you first need to find TDC. You can remove the number one spark plug, Put a 1/4" 90º bend on a stiff wire down and six inches back put a 90º bend up. Put the short bend in the spark plug hole with the long end up. That is so you know the short end is down. Bring the number one piston up until it pushes the wire up. Stop when it start to go down Work the piston up and down a tiny bit until you know it is at TDC. You can then put a dot of white paint in the center of the inspection hole. With the white dot in the center of the hole and both rocker arms up loosen the distributor base and rotate back and fourth until you can see the points are just ready to open with the slightest movement. You are then in time! You will not get any closer unless your using a timing light.
for those that doubt my disassembly remark, this is how I started to work on the dead tractors I bought years ago.
https://public.fotki.com/DickL/disassembly_of_litt/
Edited by Dick L - 30 Nov 2019 at 11:00am
