200 Hydraulic Level
Rhoadesy_65 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rhoadesy_65 Quote  Post ReplyReply Direct Link To This Post Topic: 200 Hydraulic Level
    Posted: 08 Nov 2019 at 11:04am
I have not got the brakes fixed yet on the 200 yet. I had a leaking lift cylinder that i replaced, as a result i was low on fluid. Its a 22 quart fill if i remember right, and i have put 5 gals in since replacing . My issue is that when i do my pre flight check i cant seem to find the fluid on the dipstick. I add fluid every time, but it is pretty clear oil. So where could it be going, or have i just not filled it enough? Its not getting into the engine oil pan because its level doesn't change. Haven't noticed any issues with steering, the power director might grab a bit more in neutral but that seems to go away when it warms up, and when i checked the left hand brake has oil in tis housing. The only other thing i can think about is that its leaking out of the implements. Chisel plow has a small leak, and the hay mower had bad seals in it so it squirted out the smallest amount of oil. Any ideas on possible issues or am i just being paranoid?
Farmin' with 1981 7010 PD, 1983 6080, 1983 8010, Gleaner R42 in Darke County OH
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 09 Nov 2019 at 8:43pm
Is the transmission dip stick showing over full?        MACK
Joe(TX) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Joe(TX) Quote  Post ReplyReply Direct Link To This Post Posted: 10 Nov 2019 at 11:08am
If hydraulic fluid is coming out in  the brakes, It's transferring into the rear end through the seal on the PTO shaft.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 10 Nov 2019 at 8:40pm
Or PD seal. Replace both when it is apart.        MACK
This page was generated in 0.264 seconds.
