Agco paint Question
jim View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jim Quote  Post ReplyReply Direct Link To This Post Topic: Agco paint Question
    Posted: 12 Aug 2010 at 4:30pm
Been using some Restoration series paint from Fleet farm. Tha Allis Orange is about $45. a gallon. Been buying the Allis cream colored paint from Agco. Cannot remember the price, but only avaliable in quarts and it covers very well. I am impressed with the way it covers even though it is such a lite color. I thought I would try some Agco Orange paint. Wow about $90. a gallon. I have been painting some John Deere tractors and have learned that John Deere paint covers extremely well and at about $56. a gallon is a pretty good value. I thought Allis Orange thru Agco would impress me as much as JD green paint thru JD. However at $90. a gallon I don't think I will try. Will stick to the paint I get at Fleet Farm. I think it is made by Valspar. Any thoughts?
Jason(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jason(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 12 Aug 2010 at 5:54pm
What shade of Ac orange did you buy? Last time I priced PO #1 though AGCO it was $45 a quart (only avail. as spray cans or quarts) and had to buy 4 quarts, that $180 a gallon for PO #1! In my experience tho, AGCO does seem to cover nicely. I usually start with a couple coats of primer, then 1-2 coats of  AGCO Corporate Orange (sanding between coats), then a final 2 coats of AGCO PO #1 or PO #2 depending what year I'm doing (sanding between each coat also). No clear coat or hardener tho' (they didn't come from the factory with clear coat or hardener!)
Last time I did painting was about 3 years ago and AGCO Corporate Orange was about $35-$45 a gallon, if my memory is correct. That's way I use it as a base coat.
Chalmersbob View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chalmersbob Quote  Post ReplyReply Direct Link To This Post Posted: 12 Aug 2010 at 8:21pm
Orange paint is a yellow base paint and it does not cover well. It's just the nature of the beast. It doesn't matter what brand. I use the hardner in my paint because it will hold up better. Th factory paint had lead in it, and held up better then the paints made today.
I know none of us do it, but we should be wearing protective gear when we sand the paint on the old tractors. Bob
Reeseholler View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Reeseholler Quote  Post ReplyReply Direct Link To This Post Posted: 04 Sep 2010 at 10:55pm
I do :-) I'm only 18 and getting started young and it looks like I'm going to be doing it awhile so I mise well save myself so I can do more tractors
7060 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 7060 Quote  Post ReplyReply Direct Link To This Post Posted: 04 Sep 2010 at 11:36pm
 Ive heard that that hardener is really nasty stuff. We had been mixing it without a resporator, but was told after a couple projects that it was a must.
