Three point hitch on a WD 45 snap copler
1947WC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 1947WC Quote  Post ReplyReply Direct Link To This Post Topic: Three point hitch on a WD 45 snap copler
    Posted: 01 Oct 2019 at 10:26pm
How do I install a three point hitch on a WD 45 snapcopler
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 02 Oct 2019 at 5:22am
Allis made at least  3 point adapters. They both 'snap-in' like regular snap coupler implements then you attach your 3point implement to them.
One version allows for PTO to be used, the other doesn't.
I've bolted my 3 point implments( 5' rototiller and landscape rake) and top links  to the adapters. Makes for easy on/off operation.
JimD View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JimD Quote  Post ReplyReply Direct Link To This Post Posted: 03 Oct 2019 at 10:37am
we have a few options listed at www.oktractor.com ; Some have built their own. If you have the resources, they are not that complicated, but most folks just buy them ready to use. I'll be happy to explain the differences if you need to call me.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 1947WC Quote  Post ReplyReply Direct Link To This Post Posted: 03 Oct 2019 at 12:51pm
Hey Jay THANKS for the information.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 1947WC Quote  Post ReplyReply Direct Link To This Post Posted: 03 Oct 2019 at 12:55pm
Hey Jim, I think I got it figured out. Thanks Any way.
TimCNY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TimCNY Quote  Post ReplyReply Direct Link To This Post Posted: 03 Oct 2019 at 3:18pm
I put a 3-point conversion on mine a few years back. I'm fine with it, but if I had it to do all over again I would just buy the actual snap-coupler 3-point and change between that and the drawbar as needed. Hindsight is 20-20, just fwiw.
I need more than 200 characters for my "signature." I'd love to see that changed to 250!
ac fleet View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac fleet Quote  Post ReplyReply Direct Link To This Post Posted: 03 Oct 2019 at 7:03pm
I have 1 snap coupler to 3-pt. unit that I use. When not needed or I need snap coupler for the plow it can be removed simply by dropping the latches and open the hook in the eye. also not hard to switch to regular drawbar.
