Allis B engine rebuild |
Page 12> |
| Author | ||
Levibridge95
Joined: 23 Jan 2018 Location: Quakertown Pa Points: 69 |
Topic: Allis B engine rebuildPosted: 30 Aug 2019 at 9:28pm |
I'm gonna start my 1st rebuild in my AC B on Monday. I have new sleeves, pistons, and bearings. I got the crank grounded down to .020". Any advice to give a newbie? Definitely gonna take my time with it.
| Sponsored Links | ||
DrAllis
Posted: 30 Aug 2019 at 9:49pm |
New shims for all main caps and rod caps. New cam bearings.
WF owner
Joined: 12 May 2013 Location: Bombay NY Points: 5191 |
Posted: 31 Aug 2019 at 3:36am |
Clean everything up. After you get the most of the old grime off, use brake cleaner to finish the cleaning job.
Even though they may look fine, make sure to install new core plugs in the head. They are quite inexpensive. When you get the old plugs out, I guarantee you the back side won't look as good as the top side. Before you install the sleeves, spend some time cleaning all the surfaces. I use a razor blade and dental type picks on the (top) counterbores on the top of the block. Before you put the O rings on the sleeves, dry fit the sleeves, If they go in easily, install the O rings, lubricate them (some use vegetable oil, I use a mixture of dish washing soap and water), tihen be very careful to not twist the O rings when you are installing the sleeves. Make sure you have an Allis Chalmers Sevice Manual (not I&T). Go slow and follow the directions step by step.
Sugarmaker
Joined: 12 Jul 2013 Location: Albion PA Points: 8662 |
Posted: 31 Aug 2019 at 7:56am |
Levi,
Yes take your time. I have never done a B. But the overhaul on the WD45 engine this spring made me better appreciate these old tractors. I spent a lot of time cleaning the sleeve seats and getting the sleeve protrusion correct. Make sure to clock the rings. Assembly lube on just about everything! Have fun and enjoy the process. Pictures can help along the way too. Regards, Chris
Dick L
Joined: 12 Sep 2009 Location: Edon Ohio Points: 5093 |
Posted: 31 Aug 2019 at 8:05am |
I always set bare new sleeved down in the hole and make sure they will turn by hand 360º before installing the O rings. I use a die grinder with a flapper drum to clean the bottom bore. I have had one area the took more flapper sanding to get the sleeve to set down square and turn 360º. If they are not turning I use bluing and set them down without turning to read where the bluing is being scraped off.
After the sleeves are set and held down with a short 7/16" cap screw with a washer I put each ring from a set down in the sleeve and check the end gap with a feeler gage. I have found in a complete boxed ring set a pack of rings with an over lap rather than a gap. Even though you have a fresh ground crankshaft with matched bearings check each bearing with plastigage for clearance. Making sure the bearing is properly lubed and torqued, rotate the crank to make sure turns free before installing another bearing. Main and rod caps are not new and could have been distorted and could be a couple thousands wider at the bottom than the sides causing them to be tight with a good reading. |
steve(ill)
Joined: 11 Sep 2009 Location: illinois Points: 90897 |
Posted: 31 Aug 2019 at 8:13am |
you had the crank ground... AND you got matching bearings for it from the grinder ?
no shims needed if you MATCH the new bearings to the crank. did they machine the rod journals or just the mains ?
CTuckerNWIL
Joined: 11 Sep 2009 Location: NW Illinois Points: 22825 |
Posted: 31 Aug 2019 at 10:00am |
Grinding the crank and getting matching bearings does NOT mean you can eliminate the shims. Only line boring will allow to assemble without the proper shims. |
Dick L
Posted: 31 Aug 2019 at 11:44am |
The rods have to be bored also or what is called reconditioned. The were manufactured with a spacer the thickness of the shim packs. The crankcase would have also been line bored with spacers for the mains. Without the shims the holes for bearings are out of round. |
Gerald J.
Joined: 12 Sep 2009 Location: Hamilton Co, IA Points: 5636 |
Posted: 31 Aug 2019 at 1:12pm |
Shop manual is at:
http://geraldj.networkiowa.com/Trees/Allis-Chalmers-G-B-C-CA-Service.pdf Gerald J. |
steve(ill)
Posted: 31 Aug 2019 at 4:49pm |
YEP.......... guess I was reading WAY TOO MUCH Into his bearing statement.. It was more of a question , but your right, he didn't say anything except crank grind.
Levibridge95
Thanks(1)
Posted: 31 Aug 2019 at 4:52pm |
The machinist said to get .020" bearings. I got the rebuild kit from jim danforth @ oktractor. Did new valves and work on the head.
WF owner
Posted: 31 Aug 2019 at 9:48pm |
A bit of advice. After you open your -.020 bearings, check them to make sure they are the right bearings !!! I know this from a very recent overhaul of a G226 (Thank you DrAllis) ! My machinist checked the crank on my engine and said it would be fine with new standard main bearings. I ordered a set of standard bearings. The box said standard bearings. I put them in and just snugged the main caps. I couldn't turn the crankshaft. After trying some other things (removing the cam) DrAllis suggested I check the size of the bearings. I looked again at the box and told him the box said standard. He repeated to check the actual bearings. Guess what ! The bearings said .020 ! For some reason the bearings were in the wrong box. The bad part is that someone probably got a box that said .020 and I bet his engine turned very easy (for a while!). DrAllis told me it happened tp him before. I will ALWAYS check them in the future. I now have a set of .020 bearings for a G226 that I will never use and I'm out $120 for a new set of standard bearings. If you have the right bearings, you should use a full new shim pack for each bearing. Check your clearance with Plastigauge to be sure ! Sorry so long!!!
Levibridge95
Posted: 31 Aug 2019 at 9:51pm |
WF owner
Posted: 31 Aug 2019 at 10:01pm |
When you get the shim pack, you will probably think it contains 6 shims (2 for each bearing). In reality, there are (usually) 24 shims. They are stuck together and you have to really look at them to realize that each pack contains four shims.
Theoretically, if your crankshaft is freshly ground, you should use a full pack and have the correct clearance. The original purpose of the shims was that you removed shims as the crankshaft wore, to maintain the correct clearance. I, personally, always check the clearance (even on engines that don't use shims) to check the correct clearance.
steve(ill)
Posted: 01 Sep 2019 at 8:36am |
a "SHIM PACK".... is normally a few shims together that measure .006 inch... A PACK goes on each bearing cap bolt........ don't let the bearing touch the shim, just the CAP face.
CTuckerNWIL
Posted: 01 Sep 2019 at 9:41am |
The original laminated shim pack is .010 thick not .006 |
nella(Pa)
Joined: 11 Sep 2009 Location: Allentown, Pa. Points: 3145 |
Posted: 01 Sep 2019 at 11:31am |
X2 I always plastic gauge my bearings to .0003. Never spun a bearing or had knock. After I lubricate the sleeve and put on the o rings, I take a round screwdriver and slip it under the o ring and rotate the screwdriver around the outside of the sleeve to be sure that there isn't any twists in the o ring.
Edited by nella(Pa) - 01 Sep 2019 at 11:33am |
Levibridge95
Posted: 01 Sep 2019 at 3:01pm |
Hey thanks for the help so far. I appreciate it. Can't wait to get my B back to get her.
CTuckerNWIL
Posted: 02 Sep 2019 at 9:11am |
I think you meant .003, that extra 0 would make it pretty darn tight ![]() |
IBWD MIke
Joined: 08 Apr 2012 Location: Newton Ia. Points: 4284 |
Posted: 02 Sep 2019 at 9:21am |
Edited by IBWD MIke - 02 Sep 2019 at 9:23am |
Steve in NJ
Joined: 12 Sep 2009 Location: Andover, NJ Points: 12071 |
Posted: 02 Sep 2019 at 9:36am |
If you have the engine align bored, you don't have to worry about shims. Have the rods resized and your ready to rock n' roll......... Steve@B&B
Alvin M
Posted: 02 Sep 2019 at 9:45am |
That His How I Do All Mine
Dick L
Posted: 02 Sep 2019 at 10:22am |
That is how rich people do things. They used shims in the first place because they knew everyone was not rich!
I line bored and resized the rods on my C for pulling. Been poor ever since. My old Chevys were shimmed also. |
nella(Pa)
Posted: 02 Sep 2019 at 10:28am |
I got one too many zeros in there, it should be .003. Thanks for catching the mistake.
Levibridge95
Posted: 02 Sep 2019 at 11:26am |
WF owner
Posted: 02 Sep 2019 at 12:23pm |
The last time I inquired about line boring (a long time ago), I was quoted $350 (or more). I have a bunch of these engines that lived 60+ years with shims. Since they will never work as hard as they did in their earlier life, shims work for me.
CTuckerNWIL
Posted: 02 Sep 2019 at 4:03pm |
When I rebuilt Lena, the 35 WC, it had been rebuilt at least twice before and the main bores were not round at all. I put .006 shim in them and used a good Sunnen hone to make them real close to round. Everything cleaned up except maybe an 1/8 inch of the diameter right at the parting line.
I had the crank ground and dropped new bearings in and it checked between .0025 and .003 with plastigauge and rolled over fine. I expect it to outlive me. It's only had maybe 100 hours on it since the rebuild . |
DaveKamp
Posted: 02 Sep 2019 at 8:21pm |
Well... I'm certain it was a function of economics, but I don't think that representation is really accurate. I would venture an educated guess that they used shims in the first place, because it yielded a result that was appropriate for the combination of manufacturing economics, tooling systems, and consistancy in end results that they felt most appropriate. Align boring is a resource-intensive process, and keep in mind that resources include, but aren't limited to materials, manpower, or machinery... or TIME. In the end, they also kept close to their criteria, the ability for a man, working in a dirt-floor machine shed, with an oil-lantern, the ability to do as much as possible, with the least amount available. Shims DO have their benefits.
Dick L
Posted: 03 Sep 2019 at 6:06am |
DaveKamp, Your sarcasm meter is defective. After buying an overhaul kit many do not have extra money laying around to put out three to four hundred into line boring, resizing rods or other costly items.
When I was into stock car racing with two little ones at home I headed home after stopping at the parts store. I looked over in the seat beside me and spotted a note my wife had given me that morning. It said stop and get two gallon of milk on the way home. I had spent all my cash and had to stop at a local store and charge the milk. That ended my racing dreams. Food and shoes for my little ones instantly became more important than the thrill of turning left in a cloud of dust in front of a grandstand of people hoping I would be taken away on a stretcher. I assume people starting into old tractors have a passion with limited funds as I did. Allis called out the shims as a way to get more life out of the engine. It was also used for that in the 1920's auto engines. All three of my 1920's Chevys have shimmed rods. |
Steve in NJ
Posted: 03 Sep 2019 at 6:23am |
C'mon Dick, racing is one thing. Rebuilding a 4 cylinder Tractor engine is another. The two can't even be comparable! I'm no rich guy by no means, but getting an engine align bored and rods resized and doing it the more "accurate" and upgraded way to me is money in the bank! You make it sound like you gotta' borrow on yer' house to rebuild the engine! When you have limited funds, you SAVE till you have enough to get the job done. This is 2019 not 1920.......
Steve@B&B
Page 12> |
