Putting a transmission behind a 301
simplemanlivestock View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote simplemanlivestock Quote  Post ReplyReply Direct Link To This Post Topic: Putting a transmission behind a 301
    Posted: 30 Aug 2019 at 3:34am
I'm in the process of gathering parts for a rat rod that I'm putting together for a national build off. It's a 301 from a 7020 tractor. Does anyone have experience with putting a conventional transmission behind one? I'd like to run a Spicer 6+. Where I'm running a 2 speed rear from an old farm truck, the 7th gear overdrive in the 6+ will give me excellent low rpm highway cruising speeds.
Michael V (NM) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Michael V (NM) Quote  Post ReplyReply Direct Link To This Post Posted: 30 Aug 2019 at 7:02am
find a power unit with a sae bell housing... I've been interested in something like this, but building a gooseneck toter, but using an Allison auto..Google fuller transmissions, you can find out all kinds meet stuff such as ratios, trans weight, etc.
Edited by Michael V (NM) - 30 Aug 2019 at 7:07am
exSW View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote exSW Quote  Post ReplyReply Direct Link To This Post Posted: 30 Aug 2019 at 7:09am
Couple guys have put them in pickups. Search YouTube.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 31 Aug 2019 at 10:00am
Biggest concern once adapt to Automotive is fuel system, the tractor pumps do not have advance/retard mechanisms as far as I am aware and cannot adapt to altitude changes. May want to look into that as well.
Post Options Post Options   Thanks (0) Thanks(0)   Quote simplemanlivestock Quote  Post ReplyReply Direct Link To This Post Posted: 01 Sep 2019 at 12:54am
Thanks for the input. I plan on running a p7100 pump from a 5.9 Cummins I found to make it more drivable. As far as a transmission is concerned, I think I'm going to end up with an NV4500 5 speed from a Dodge pickup. I'm beginning to think this is my best option...?
