F3 perforated sieve
Ben (MI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ben (MI) Quote  Post ReplyReply Direct Link To This Post Topic: F3 perforated sieve
    Posted: 29 Aug 2019 at 5:13pm
I should know this. On the F3 cleaning shoe is the perforated sieve ALWAYS used in corn and soybeans? Or is this not needed at all, running only the chaffer and adjustable sieve?
A Deere guy is asking me.
Edited by Ben (MI) - 29 Aug 2019 at 5:14pm
Part time farming with a 1980 7060 and 1984 F3 hydro.
AC7060IL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC7060IL Quote  Post ReplyReply Direct Link To This Post Posted: 29 Aug 2019 at 6:16pm
Chaffer is positioned on top & sieve is positioned under chaffer. I have seen a dedicated corn machine have a sieve deleted. I have also seen perforated sieve used. A correctly set adjustable sieve can offer excellent results with a huge range of settings. Harvest seed size can vary greatly. Harvest conditions can vary too. So un-threshed pods & cob pieces can easily be returned with an adjustable sieve.
Edited by AC7060IL - 29 Aug 2019 at 6:19pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ben (MI) Quote  Post ReplyReply Direct Link To This Post Posted: 29 Aug 2019 at 8:04pm
Thank you 7060. Do I understand then that the perforated sieve is only there for additional cleaning?
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 29 Aug 2019 at 10:55pm
I seen a bean screen in a A2 years ago. Was in place of adjustable sieve. I would think it would choke capacity some but deliver better sample. I've had conventional Gleaners for 38yrs and only used the adjustable chaffer and sieve.
Edited by SteveM C/IL - 29 Aug 2019 at 10:59pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ben (MI) Quote  Post ReplyReply Direct Link To This Post Posted: 30 Aug 2019 at 6:41am
Thank you both! My mechanic and I continue to try to figure out why I have occasional grain leakage at the front of the shoe when it is running full or on a sidehill. He asked me what that screen was for, it's coming out.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 30 Aug 2019 at 9:11am
The chaffer is on top. The adjustable sieve is underneath. Sometimes the adjustable sieve is replaced with a screen, of different hole sizes. On a corn/soybean machine there are fine screens underneath the sieve that can be exposed for letting out dirt and weed seeds. You have to pull blanks out of the shoe to expose the fine screens for this. You must slide the blanks back in for oats and wheat.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ben (MI) Quote  Post ReplyReply Direct Link To This Post Posted: 30 Aug 2019 at 9:43am
As always I appreciate your expertise Doc.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 30 Aug 2019 at 11:03am
71302627 in F2-F3 partsbook is the pan under the sieve that has the perfs to let weed seed etc pass through and go to return. There is a "cookie sheet" that slides in on top of it to make a solid blank like you would want in wheat. If that panel is perforated,the return ele should have the screen on the bottom of it too. It should have a solid shield to pull up and cover screen. With those screens open,you can keep a lot of fines and weed seed from going in the bin. Good idea if using on farm storage. If going to the elevator,sell it unless too much for sample.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC7060IL Quote  Post ReplyReply Direct Link To This Post Posted: 30 Aug 2019 at 11:53am
Excessive grain into fan housing is caused by overfilling the cleaning shoe(chaffer/sieve). This can be caused by numerous dynamics
-higher grain moistures(let it dry down more),
-higher grain yields(lucky you!)
-terrain{hills}(add a hillside blower kit or if it already has one, then service it for constant air pressure).
-choked chaffer/sieve(open them up to allow max grain flow while limiting trash in sample),
-choked fan setting(open all the way),
-slow clean grain auger(speed up kit),
-worn/missing paddles on clean grain elevator.(service it),
-straw walkers position( forward or backward),
-etc, etc, etc.....).
I’d add excessive machine forward speed, but if it’s header & threahing(cylinder/concave) are keeping up & doing well, then reducing forward travel speed is counter productive. BUT, if you can’t remedy all the other limiting dynamics, then yes, you are forced to slow down forward travel.
Edited by AC7060IL - 30 Aug 2019 at 11:57am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ben (MI) Quote  Post ReplyReply Direct Link To This Post Posted: 31 Aug 2019 at 7:49am
Thanks again. I can't stress enough how much all of you help me!👏👍
tbran View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tbran Quote  Post ReplyReply Direct Link To This Post Posted: 31 Aug 2019 at 2:06pm
The perforated screen was to let out the weed seed and such fines... why dump weed seed it on your ground - sell it!  :-)  The later model Corn and soybean models did not have perforated screens... some customers demanded it so it was an option for a few years but finally dropped.  We always told customers never remove the 'cookie sheet' for two reasons, 1 it is not needed 99% of time and 2 it always got lost and was never to be found when we traded it back in -- had to buy / make a bunch in  40 years... to make them go in wheat...  grrr
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 31 Aug 2019 at 9:41pm
Yeah,my F2 is missing the cookie sheet. Would just as soon have one.
Post Options Post Options   Thanks (0) Thanks(0)   Quote tbran Quote  Post ReplyReply Direct Link To This Post Posted: 31 Aug 2019 at 9:45pm
they also had perforated door boots and unloader tubes..
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 31 Aug 2019 at 10:10pm
Right you are! Wouldn't you enjoy harvesting whatever needed that much screen action!
This page was generated in 0.251 seconds.
