HELP!!! 1996 Agco 5670 3 point not working
Whacky Farmer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Whacky Farmer Quote  Post ReplyReply Direct Link To This Post Topic: HELP!!! 1996 Agco 5670 3 point not working
    Posted: 22 Aug 2019 at 3:11am
I recently purchased an Agco 5670 that has been sitting about 2 years. It runs great and everything is working except for the 3 point hitch. It's stuck in the up position. When I move the position lever it will go up and down about 1/2 inch, but that's it. Any help would be greatly appreciated.
Edited by Whacky Farmer - 23 Aug 2019 at 9:16am
ranger43 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ranger43 Quote  Post ReplyReply Direct Link To This Post Posted: 23 Aug 2019 at 7:52pm
we bought a 5670 new and have had some problems with the hydraulics. Had a spool stick one time and also had o-rings fail in pump 2 times. As for the 3 point If you have the position lever all the way forward along with the depth adjustment as you described and it may be a stuck spool or if it has been sitting that long check condition of the exposed part of the cylinder that drives the 3 point arms for pitting.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Whacky Farmer Quote  Post ReplyReply Direct Link To This Post Posted: 24 Aug 2019 at 12:30am
Thanks Ranger43. I will take a look at the spool valve, and the cylinders. Fingers crossed
