720 Hydro Filter/ Fluid
dertz19 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dertz19 Quote  Post ReplyReply Direct Link To This Post Topic: 720 Hydro Filter/ Fluid
    Posted: 16 Aug 2019 at 11:18am
Any recommendations on brand/ type, source, etc.?
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 16 Aug 2019 at 9:16pm
I need to verify but I think I put Dextron II transmission fluid in mine. Any Simplicity dealer should have a filter. Carquest also carries the filter.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 17 Aug 2019 at 8:30am
We have the filters in stock, but if you have a Napa store near by, walk in and ask the counterman for a Napa Gold 1068. You'll have to remove the fender to install it, but its a large filter and it just fits between the fender!   Oh, and BTW, Rob is right Dexron II
Steve@B&B
Edited by Steve in NJ - 17 Aug 2019 at 8:35am
Dave (NE) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave (NE) Quote  Post ReplyReply Direct Link To This Post Posted: 17 Aug 2019 at 11:19am
I used Fram PH16 filter.  Didn't have to remove the fender.  Also, I think I used Dextron III, but would have to go look at the container to verify.  Dave
Do not argue with an idiot. He will drag you down to his level and beat you with experience. Mark Twain.
BrianC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BrianC Quote  Post ReplyReply Direct Link To This Post Posted: 17 Aug 2019 at 6:09pm
I have the WIX51307 installed. Should be same as Napa 1307.  It appears to be not as long as the 1068. Also, with 51307, the end is more rounded, maybe allows for more wiggle room. Anyway, it fit with fender in place and as installed I measure .52" clearance.
My machine is actually a 620. I do not see an opportunity to have the fenders set further inboard (thereby reducing clearance).
If there is an issue with using a 51307 vs 1068, would appreciate a heads up.
Post Options Post Options   Thanks (0) Thanks(0)   Quote dertz19 Quote  Post ReplyReply Direct Link To This Post Posted: 18 Aug 2019 at 10:24pm
Thank you all for the input!!!!
