wd rear pto hyd pumps
chevy1946 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote chevy1946 Quote  Post ReplyReply Direct Link To This Post Topic: wd rear pto hyd pumps
    Posted: 10 Jul 2019 at 7:02am
kinda new here, looking for info on serving my pto hyd res, had to remove front bucket for engine replacement. any help would be great
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jul 2019 at 9:18pm
Don't under stand question, could you rewrite question?        MACK
Adam Stratton View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Adam Stratton Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jul 2019 at 9:38pm
Do you have a pump that attaches to the PTO shaft? There were several different types of them that could be plumbed all sorts of different ways. If your talking about your normal factory hydraulic reservoir, there should be a cap under the gas tank on the left side,basically just below the sediment bowl
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jul 2019 at 9:51am
The PTO has nothing to do with the factory hydraulic system on a WD. If you have a PTO driven hydraulic pump you need to figure out what you have, and how to check oil level.
 Post a picture.
 The WD hydraulis fill port has a dipstick and is on the left side of the torque tube, tucked away inside the frame rail.
This page was generated in 0.097 seconds.
