720 deck height adjustment
rrhead(SD) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote rrhead(SD) Quote  Post ReplyReply Direct Link To This Post Topic: 720 deck height adjustment
    Posted: 02 Jul 2019 at 10:34am
How is the height adjusted on a 720 60" deck. I've been using the hydraulic lever to do this, but hard to be consistent. Thanks, rrhead(SD)
2 WDs,WD45,D-14,D-17,D-19D,180,7020,6080FWA,6080 2wd, 6080 2wd(cab),8050FWA,8550,4W-305,Massey 8250. Gleaner L3, R62 &R65 Agco-Allis 1616H & 1920H, AC 720, Terra-Tiger
Dusty MI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dusty MI Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jul 2019 at 12:30pm
That T handle on top of threaded shaft at outer ends at rear of deck, one at each end.
Post Options Post Options   Thanks (0) Thanks(0)   Quote rrhead(SD) Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jul 2019 at 4:40pm
I figured that sets the back of the deck. Is there any way to set the front? rrhead(SD)
den/southern illinoi View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote den/southern illinoi Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jul 2019 at 7:05pm
That sets front and back. If you watch the rods that tie the back to the
front of the deck you will see that it changes the angle of the front mountings.
Den
Own 4 wheel 20, 5020 and associated equipment and 1 electric forklift. Also a 720 garden tractor, 720 Diesel. 620 and soon a 616 garden tractor.
Post Options Post Options   Thanks (0) Thanks(0)   Quote rrhead(SD) Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jul 2019 at 9:05pm
Ok, that helps allot. I will take a good look at it tomorrow. Thank you very much for the help. rrhead(SD)
