190XT 3 lost all hydraulics instantly
youngorange2000 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote youngorange2000 Quote  Post ReplyReply Direct Link To This Post Topic: 190XT 3 lost all hydraulics instantly
    Posted: 09 Jun 2019 at 9:52pm
I was moving wagons from farm to home and pulled out on the road empty, opened up the throttle and like a light switch lost all hydraulics, ended up in the ditch and took out my own fire marker in the process just thankful it wasn't with 240bu of corn. The tractor was working perfectly fine for the hour or so intel then. I have lost steering before and that was a piece of gunk in the splitter valve on the back of the hydraulic pump checked there, no change also no new or missing noises. any help would be much appreciated. its my main tractor and moneys very tight right now
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jun 2019 at 6:24am
Splines are worn out on gear that drives hydraulic pump.       MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote youngorange2000 Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jun 2019 at 11:45am
I took the pump apart today and found that the 4 brass plates are chewed up bad,gears are shot,shafts are wore bad. also the housings look good. Now I am wondering if I can replace the bairngs in the pump or are they a non serviceable part of the pump?
Dave H (NE) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave H (NE) Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jun 2019 at 12:01pm
yes the bearings are replaceable
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jun 2019 at 11:01pm
Time you buy all the parts,you'd be ahead to buy new pump. Shouldn't need another one in your life time. Get used at salvage? What's it going to be like?
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jun 2019 at 9:40pm
If bearings are shot, I'm sure the steel housings are shot. Run your finger around top and bottom where gears run. If they are shot, you might cut your finger. Be careful.       MACK
