D17 262 Governor
wade89 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wade89 Quote  Post ReplyReply Direct Link To This Post Topic: D17 262 Governor
    Posted: 05 Jun 2019 at 9:58am
Picked up a D17 diesel that someone put a 262 combine motor in. The governor/throttle control rod looks to be wrong and was jammed behind the distributor. Took rod off, because it needed an extra 1-1/4” to come down to an idle and when that rod goes forward it needs almost an extra 3” to run anywhere near wide open. Does anyone have a picture of a D19 setup or similar conversion? Debating a cable type throttle system if I cant figure out the geometry that will work on this tractor.
CAL(KS) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CAL(KS) Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jun 2019 at 11:03am
